alignment specs
Old Jun 23, 2011 | 08:00 AM
Iowa999's Avatar
Originally Posted by Dallas J
^^ Exactly what I was talking about. Its not a ton, but any extra caster Ill take.
Caster is nice for the "free" camber in turns, but also causes the jacking effect in that turning now raises the outside front wheel and lowers the inside front. On something like a 2G DSM, the chassis of which had lousy torsional rigidity, this was definitely worth it. Do you really think it's a positive on an Evo, too, which has a much stronger chassis?
Old Jun 23, 2011 | 09:02 AM
Dallas J's Avatar
Veteran: Army
Using the Tein plates its set to the only way you can add any amount of camber. It may be possible to re-drill the holes on the plate to allow it to be mounted in a different orientation, but it does give a little extra camber/caster from the stock orientation in this manor. IIRC, its 1-1.5* extra caster and camber.
Old Jun 23, 2011 | 09:27 AM
Iowa999's Avatar
What about putting the plates on the wrong side of the car? Would that place the slot in the desired direction?
Old Jan 20, 2016 | 11:48 PM
krisdlm's Avatar
Bringing this thread back, I am installing the Tein front camber plates tomorrow and I wanted to get some feedback on them. I was going to use Smike's guildline for the -2 bolt selection up front and -1 to -1.5 in the rear. Zero toe all around. Zero thrust angle
weeeeeeeeee
20
Apr 4, 2017 06:44 PM
High_PSI
Mar 12, 2017 08:19 PM
wreckless969
Mar 2, 2017 11:51 AM
seven10
Feb 19, 2016 09:34 AM
blackbalts
Jan 27, 2016 06:08 PM
