Oops, staggered offset question, same size tire.
Old Jun 17, 2011 | 12:17 PM
ChadS's Avatar
So I picked up a set of used rota grids 17x9.5 I was told.
Long story short I had someone remove the 235 tires that were on them and he chipped the paint pretty good on 2 of them, he put my new 255/40/17 on all 4.
At this point after a discussion he agreed to cover the two he messed up so I ordered two new 17 x 9.5 +30 offset. I went to a new place today and had the tires swapped from the two marked up wheels to the two new wheels. When I picked them up I discovered the old wheels had a rota sticker on the inside that read 17x9 +25.
So now the question is I have two 17x9.5 +30 and two 17x9 +25 with 255/40 tires on them. Can I run the 9.5's in the front and 9's in the rear and call it a day or will I end up needing spacers or should just get two new 17x9's? Will it hurt anything?
Thanks.
Old Jun 17, 2011 | 12:21 PM
Neal@tirerack's Avatar
Best would be to get another pair that matches, but if you didn't, I would run the wider ones in the rear. It will probably come very close to looking the same as the difference in offset and width will cancel each other out.
Old Jun 17, 2011 | 12:39 PM
RJones's Avatar
I always run wider up front...
I don't think you can fit a 9.5 +30 up front without spacers though. Easiest would just be to buy a 5 or 10mm spacer and run the 17x9.5 in front and 17x9 in the rear, or you could just buy another pair of wheels to match the others.
I wouldn't run a wider wheel in the rear unless you don't care about handling characteristics.
Old Jun 17, 2011 | 01:12 PM
Buyer Beware
I would never run such a mis-match, although some say it wont hurt. I like all my components to match, especially when it comes to wheels/tires
Old Jun 17, 2011 | 01:26 PM
KOOLER's Avatar
+1
Wider in front is better for cornering. +5 mm is not a big deal in any case.
I do run 9.5 +30 in front 275/35/18 w/o rubbing on pretty much stock fenders.
Old Jun 17, 2011 | 02:22 PM
Ludikraut's Avatar
Running a different offset rims, especially 5mm, is no problem. It's different tire widths and diameters that get you into hot water with the AWD system. I run 5mm spacers up front - have been doing so for years, even with the stockers.
l8r)
Old Jun 17, 2011 | 07:45 PM
ChadS's Avatar
I believe this adds 14mm to the backspacing (according to offset calculator), stock is 139.x as far as I remember. Does that mean I should run 10mm spacers or would 5mm be ok? Also could I even get away with being 14mm closer to the strut or is that cutting it too close? I might be able to test fit tomorrow and find out, just trying to figure it out ahead of time.
Old Jun 18, 2011 | 07:44 PM
ChadS's Avatar
I quit.
After all this turns out the tires I traded a friend for were 255/45s and I obviously was not paying attention. They are too large a diameter to fit which I realized tonight when I went to test the 9.5" wheel on the front. I hate life right now. Spent $75 the first time to swap the 4 when the kid messed the wheels up. Spent another $50 to swap two of the messed up wheels to the wrong size 9.5" at a different shop.
Now I need to buy 4 new tires and get them mounted. At least the hankooks have a rebate this month. Dammit.
pd9000
13
Aug 14, 2012 04:36 PM
ca18hatch24
Apr 26, 2012 09:36 PM
ChadS
May 14, 2011 04:07 AM
Boltz.
Feb 5, 2011 08:22 AM
Tarmac9
Oct 7, 2009 07:24 PM
