Max rear rotor thickness?
Just curious if anyone knows that max rear rotor thickness that can be run on the OEM clappers? I know that OEM rotor thickness is 0.87" and I have a clearance of 1.09" in the clapper with pads installed.
Working on making my own BBK with OTS parts. I would like to run a 0.95"-1.00" thick rotor and lateral runout tolerances will fit the 1.09" space I have provided the excursion of the pistons do not "clamp" closer to the rotor when fully installed and the system being pressurized.
TIA
TIA
