spacers, studs, and lugs help
Old Sep 19, 2011 | 06:33 AM
wasFWDnowAWD's Avatar
few questions in regards to wheel spacers and wheel studs....
1) what is the oem wheel stud length?
2) whats the thickest spacer we can use with oem studs and lugs? any different with aftermarket lugs?
3) if you do get extended wheel studs and spacers for aftermarket wheels, what is the proper setup to revert back and use oem wheels for winter? being as oem lugs arent made for longer studs...
4) is it still highly recommended not to use aftermarket (coned/tapered) lugs with oem wheels?
5) what are the biggest concerns about using spacers on a daily driver? and at road course or autox events?
6) do you have hubcentric rings for your volks? is it really needed especially with tapered lugs?
OT question:
if you have 18" wheels and get a flat, how safe is it on the car to use the spare 17"? would buying an evo X spare tire be better? eventually getting 265/35/18 tires for my 18x9.5 wheels. would the evo X spare be the same size. or what options do you have.
Old Sep 19, 2011 | 09:51 AM
BenJ's Avatar
Couldn't tell you
5mm
If you are going to be reverting back and forth between stock lugs and aftermarket and still want to run a spacer, you can just buy bolt on spacers seen here: http://motorsport-tech.com/wheel_adapters.html
Correct
No issues here, been running them for awhile.
Yes and no. The hubcentric rings just help in ensuring that your wheels are truly centered on your hub. The acorn style lugs do this too, just shake the wheel a little before tightening all the way and you will be fine. My personal recommendation would be to get the hub/wheel centric rings though; no reason not too.
OT question:
I wouldn't recommend long term driving like this, but a short distance with easy driving will be fine. Ideally, your outside diameter will be the same.
RallySport Direct
EvoX 'For Sale' Wheels / Tires
90
Sep 1, 2015 09:25 AM
essej
May 18, 2015 12:41 PM
vtluu
25
Mar 31, 2013 02:39 AM
ksemski
Jul 24, 2012 03:27 PM
06redrocket
10
Mar 8, 2011 06:45 PM
