Bad Allignment Specs
Old Sep 20, 2011 | 11:27 AM
eve-slow's Avatar
I would like to get opinions on how horrible this is:
Dave
Old Sep 20, 2011 | 11:30 AM
Smike's Avatar
Rear toe sucks.
Rear camber is much more adjustable/tune-able as well. I'd have rear better matched on camber. Get that toe sorted out.
Old Sep 20, 2011 | 12:04 PM
mouseIX's Avatar
What is the concern? Is this pre-alignment, post alignment, as good as it gets...?
Yes it's out most importantly rear toe, but you can tell that from the picture.
Old Sep 26, 2011 | 11:51 AM
eve-slow's Avatar
Little better :
Old Sep 26, 2011 | 12:18 PM
Smike's Avatar
No its not. Why do you have almost -2 rear camber now?
And front went from -0.6 to -2? How?
Old Sep 26, 2011 | 12:34 PM
GTWORX.com's Avatar
1st alignment was awful.
2nd is a little better, but you have too much rear camber. What are you aiming for? How do you use your car?
- Andrew
Old Sep 26, 2011 | 01:44 PM
eve-slow's Avatar
I wanted around -2 in the front. The 1st job was done by some shop that didn't understand the camber plate adjustments.
The rear is too much, but I was told that with less the toe was way off. I'm guessing that my rear toe bolts are rusted/seized. Isn't getting the toe corrected more important?
I use my car on the streets and occasional track days.
Is the rear camber really too much that it will have negative affects?
Thanks for helping.
Old Sep 26, 2011 | 03:02 PM
Smike's Avatar
Your tires are going to last about 5000 street miles. Handling wont be very good. Yes, rear camber is really too much.
Old Sep 26, 2011 | 03:34 PM
BigDaveDogg's Avatar
Where did you end up going for the 2nd alignment?
Old Sep 26, 2011 | 04:45 PM
eve-slow's Avatar
^Discount. What specs would you think would increase tire longevity to 15,000 miles?
Old Sep 27, 2011 | 04:12 AM
Smike's Avatar
Do not go to major chains. Just take my word on this.
Find a local mom/pop shop that has techs in it who are not 18. Talk with them about what you want. If they give some BS about well the computer only lets me do X - walk away. Alignment racks are just tools. If you cannot work beyond what some screen says - you're an idiot/untrained/lazy.
All out tire, less handling:
Front:
-1, zero toe
Rear,
-0.5, zero toe
General handling, less tire life:
Front:
-2, zero toe
Rear:
-1, zero toe, zero thrust angle
Race:
Lots more, depends on more too.
Old Sep 27, 2011 | 05:18 AM
eve-slow's Avatar
^This is exactly what I asked for. -2 -1 & 0's. Thanks Mr. Mother****er.
Old Sep 27, 2011 | 05:47 AM
Smike's Avatar
Not exactly what you got then, eh?
Old Sep 27, 2011 | 07:42 AM
eve-slow's Avatar
Nope!
I need to replace the driver's side rear toe bolt. Got an extra?
Old Sep 27, 2011 | 08:55 AM
Smike's Avatar
Take of and soak in Coke and/or PB Blaster.
