Caliper Flex?
Old Oct 9, 2011 | 11:24 PM
barneyb's Avatar
^^^^Interesting stuff
Old Oct 10, 2011 | 06:17 AM
JDavenport's Avatar
Originally Posted by 03whitegsr
Anybody used heat paint on the calipers to see how hot they actually get with various power and grip levels?
If the aluminum is getting to 300F, the metal is losing about 10% of it's stiffness and 20% of it's strength. Get it up to 400F and it's down 15-20% on stiffness and 60% of it's strength is gone. The strength is actually the bigger concern as you may actually be permanently deforming the caliper at high temperatures.
Have you measured the calipers piston faces to see if they are still parallel?
I'll measure the caliper piston faces later this week when I prep it for a track day this Sat. However, the street pads are wearing nice and flat with no taper, so I would suspect this is a combination heat/load situation only coming into play in track conditions. However, the car's days of being driven on the street are all but done.....
I wonder at what temp do the Brembo's turn almost black? Mine are somewhere between very dark brown and flat out black. I know I've turned my Ti shim plates that prismatic blue that indicated they have seen over 800 degF.
Old Oct 10, 2011 | 09:08 AM
barneyb's Avatar
https://www.evolutionm.net/forums/ev...ution-evo.html
Old Oct 10, 2011 | 09:56 AM
03whitegsr's Avatar
Kind of spendy, but could be used for a lot of things.
http://www.amazon.com/Genesis-Brake-...8265593&sr=8-5
Old Oct 10, 2011 | 01:55 PM
Ludikraut's Avatar
^Nice find.
l8r)
Old Oct 10, 2011 | 05:46 PM
cfdfireman1's Avatar
great solution
if you never turn!
Old Oct 11, 2011 | 01:32 PM
barneyb's Avatar
Originally Posted by cfdfireman1
if you never turn!
The thing is, these people are out there with the wrenches. Some of their ideas will work and some will be dead ends. I want to encourage them. Eventually, somebody may arrive at a new solution we will all want to use.
Old Oct 11, 2011 | 03:03 PM
It's not a new idea, the hard part is getting it to work.
Old Oct 11, 2011 | 06:58 PM
JDavenport's Avatar
The 3" duct is not a new idea, but like BarneyB, I welcome seeing any and all ideas and thoughts on how to better implement it and make it workable. I spend more in front pads and rotors than I do tires tracking my Evo. So any ideas on better cooling the brakes (and making them last longer) is welcome.
Old Oct 11, 2011 | 08:55 PM
Try some Raybestos st47's to get a hard pedal. The wear on your pads looks like rotor flex to me. Have you tried the new CL pads yet? You can burn up a set of the RC6 in one track day.
Old Oct 11, 2011 | 08:58 PM
03whitegsr's Avatar
Why do you suggest rotor flex over caliper flex?
Seems like the rotor would be considerably stiffer then the caliper as you are loading the rotor in "axial" compression. The caliper on the other hand, you are inducing bending moments in the bridge. Objects are much stiffer in axial strain then bending.
Old Oct 12, 2011 | 06:22 AM
2 piece rotors? Pretty big ones stock on an evo. Look were the wear is. Then read this. http://www.stoptech.com/tech_info/wp_knockback.shtml Also explains the low pedal that gets firm after a few pumps, maybe you notice it more after that long bumpy high G sweeper?
Randy Pobst was at a track day I attender a few years back at Road America and I asked him about this "knockback" thing on my evo. He told me he did a left foot tap up before every brake zone after any period of brake inactivity. Good enough for Randy and it works for me.
Old Oct 12, 2011 | 02:01 PM
JDavenport's Avatar
I do the left foot tap towards the end of any long straight (like the back straight at RA). This isn't knockback. I get some pedal resistance as soon as I push and some braking, but to get to hard (threshhold) braking I have to mash pretty hard on the pedal and it sinks as I do. Not a lot. but anough to hose my heel toe most of the time. Pumping the pedal doesn't help, been there tried that.
Looking at that pad, after that wear pattern sets in, then when the pads start to press on the rotor, the only thing touching on the outside pad is that lower edge. I suspect I am having to press hard enough to flex the caliper and bring the whole pad face into the rotor.
Driving it around after re-installing the RB ET700's and street wheels/tires, the pedal is rock hard and has almost no movement. Of course those pads are wearing nice and flat (even on both sides).
Old Oct 12, 2011 | 03:42 PM
makes no sense, you have equal pressure on both sides of the rotor when you hit the brakes, unless the caliper is flexing without brake application. the uneven wear is at the outside edge of the rotor on both sides, if it were indeed the caliper flexing wouldn't you see pad wear at the center portion of the rotor on one side and the outer edge on the other pad?
Old Oct 12, 2011 | 03:44 PM
put a set of rabestos st47 on her and let me know how they work.
