Fortune 500 coilover problems
Old Nov 20, 2011 | 06:40 PM
Heezayx's Avatar
Hey guys ive got the fortune 500 coilovers on my evo 8 with Rota DPT's 18x9.5
the problem im having is that my tired are so freakin wide they actually rub over big bumps, ext.
i bought my evo with them on and they were way to low, especially on the driver side front wheel well. i couldnt even fit my fingers inbetween my tire and body so i get them raised by Akuma Motorsports and it was great for a while they were still and barely rubbed but now its been about a month and my coils have definitely lowered in ride height substantially.... back to how it was when i got the car
anyone having the same problem?
Old Nov 20, 2011 | 06:45 PM
PRS's Avatar
PRS
If you can jack your car up see if the coil over has two collars under the spring. If it doesnt then its possible its spinning itself down
Old Nov 20, 2011 | 09:07 PM
son of krypton's Avatar
First do what PRS said and check to see if your collars have come loose. You'll have to have the height readjusted. Make sure those collars are super tight, checking and retightening a few days after the height readjustment. Use a flat head screwdriver and hammer the collars to tighten or use your might and tighten with the wrenches supplied.
Btw, what is the offset on your dpt's? I have the same wheels with +35 offset and 255/35's without issues, and I'm on FA 500's as well. If you have the more flush +22 offset, you might want to look into having camber setup adjusted and/or fenders rolled (probably only rear).
Old Nov 21, 2011 | 03:50 PM
Heezayx's Avatar
i have a +22.... when i went to get my coilovers raised the one guy was saying that no matter how much you raise it, ti will still rub because its actualy rubbing on the inside of the wheel well. and ive had my fenders rolled already
jayevo23
Apr 19, 2017 12:09 PM
MisterEvo9
Sep 25, 2016 08:06 PM
SpeedI2acerX
Aug 22, 2015 10:07 PM
GHEvo8
Apr 26, 2015 07:52 PM
e_kobz
74
Mar 15, 2015 10:45 AM
