Alignment specs?
Alignment specs?
I'm going to get the tires on my Evo rotated soon and noticed outsides of my front tires are terribly worn. I do drive my Evo aggressively on nice winding roads almost daily and it looks as though the understeer problem inherent in the stock setup is taking it's toll on my tires. The rest of the tread on the front tires is excellent. It's just the outsides of the tires are pretty scrubbed =/ I'm going to have the tires dismounted since they are directional and have a "true" tire rotation done. While I'm doing that can anyone suggest some alignment specs to give to my "guy" to dial out the understeer and get somewhat neutral handling? If anything I'd actually prefer oversteer to the understeer push feel that the Evo exhibits. Anyhow, thanks in advance guys/girls =)
Searching for "alignment specs" turns up "Alignment on EVO" post a few threads down the page:
https://www.evolutionm.net/forums/sh...lignment+specs
Thanks, but I did a search already and the specs posted are of stock settings which if you read my post I don't really particularly like. Anyone have any specs with a bit of the understeer dialed out?
I had no problem finding past posts using the
button:
https://www.evolutionm.net/forums/se...der=descending
Specifically this post - You have over 10 different settings in this post (Yes, there are understeer elimination settings there)
https://www.evolutionm.net/forums/sh...nment+settings
button:https://www.evolutionm.net/forums/se...der=descending
