OEM Tire Size Rubbing on front
Initially I was going to say make sure the fender liners are clipped in place. Mine rub but I run 255/40's and those just barely rub and that's partially because I don't have my liners clipped into place so it's a non-issue. After seeing those pics I'd say...ugh
You should start taking off the front suspension and look for anything that is bent and replace. After that get the frame checked and if necessary pulled. I have had cars in the past that have been salvaged that have had the frame repaired and they have been great cars. Hopefully that car was a steal.. Good luck
The car was an absolute steal. I'll do whatever necessary to get it straightened out because I'm already super attached to this machine! After all, its just a big hunk of metal... If its truly completely scrap/junk... I'll part it out and get another one. Thanks for your input!
That is exactly what I'm going to do. I have an appt. with alignment shop tomorrow. Spoke with him on the phone and described to him the situation. He can not understand how BOTH wheels appear to be back and have the same exact clearance with fender. He was looking at the front suspension/steering parts breakdown on his computer and said it looked extremely simple and could only be a couple things...but was still baffled. All we can do is start investigating which will be easier to do when the car is on the lift.
so, if you have more than ~15-16k into this car, just know that anything from here on out is money thrown out the window if you ever get rid of it
just remember, "complete steal" is all a relative term. for a salvage vehicle, a normal price (for one in the same condition as a non-salvage title) would be about 3/4 the price, a complete steal would be closer to 1/2 the price
Wow that's not much... Please explain what issue I should be looking for. Transfer case? Will it make noise? Fail? Lock up? I don't understand with ACS system putting percentage to front on limited slip differentials how that small of a difference is the end of life of transfer case... So someone who is not on top of getting their tires rotated could have over 2/32" difference in tread depth and trash their transfer case? I'm not saying mine isn't trashed but it seems fine after driving 2200 miles. Was in snow last night and front end working just fine. No noises no issues so far... Either way its not getting driven anymore until frame is straight with 4 new rubbers..
I suspect this will only affect evos with the acd and not the 8's with the mechanical tc.
Having two different rolling diameters strains the diff. Failure is from damages done. You may develop a whining sound. That will turn into grinding or lock up over time.
man my blind cousin could see that something is not right with those front tires, no normal car on this earth has wheels that are not centered in the wheel well, whoever re did that front end needs to be fired, hope it works out for you man, damn...smh
