Lightest Wheels in 17"
I guess the fact that each weighs as much as a small child wasn't accurate enough? You'll have to wait for someone to put it on a scale, I haven't been able to find specific specs on the wheel including its weight.
David at Works weighed his stock wheels on a digital postal scale a long time ago and reported 20lbs. If you need more proof than his word, then I guess you're out of luck. That's about the best information we've ever had on the site regarding the stock wheels.
Perhaps not an exact answer about the wheel, but I weighed a stock wheel and stock tire together (mounted) on a bathroom scale and got 45 pounds.
Then I weighed an Enkei RPF1 wheel (17x8) with a Hoosier 245/40R17 autoX tire (mounted) on the same scale and got 35 pounds.
Note that the Hoosier is one of the lightest 17" tires you'll ever see -- but they aren't built to be streetworthy.
Buddy Club P1QF in 17x8 is 14 lbs. That's very light. There is a big wheel weights thread in this forum somewhere that listed the weights for a lot of wheels.
__________________
"Let us help you build your JDM dream!"
www.bulletproofautomotive.com
The Real JDM - Interactive (blog)
Email: sales@bulletproofautomotive.com
Direct North American Dealers for Voltex, Mines, Varis, First Molding, HKS Kansai, Cusco, HKS, Advan, Volk, Ings+1, C-West, Work, and so much more...
Volk CE28N
My Volk CE28N's in 17x8 weigh 13.5#; my 17x9 Enkei RPO2's were cheap and weigh 17#. The Volks have the bronze anodized finish; if you want painted Volks, they're going to weigh more. They do have the JDM-pimp factor, as the other poster said. Warning, Volks aren't cheap.
You can run 255/40/17's no problem on an Evo with stock ride height and stock wheel offset (or close to it). If you lower the car, you'll need to get your offset just right. In the back of the car, there's a lot room to the inside and no caliper clearance issues. If you just drag race, 235's or 245's may be fine with the AWD traction.
Attached is a photo of the CE28N.
Enkei RPO2
Here's a picture of an Evo with the RPO2's, size 17x9 w/ +35mm offset, wearing 245/45/17 Falken Azenis tires. I like these wheels, and the Azenis wear very well but probbly aren't stickier than the Advans the car comes with. BTW, the Falkens are very tall.
Guestimated formula
Originally posted by TOMEI EVO 7
do u have an idea how much weight you save when u lighten 1 wheel by 1lb?
Example: you find wheels that are 5 lbs lighter than your current wheels. That's 5 lbs/corner, 4 corners, so 20 lbs of unsprung weight. Apply the "EJ Ratio" of 5:1, which will bring you to the equivalent of losing about 100 lbs out of the car (or the equivalent of one slightly overweight 10 yr old child, in Malibu Jack metrics
Re: Enkei RPO2
Originally posted by Nyc_Ryc
... the Azenis wear very well but probbly aren't stickier than the Advans the car comes with.
Has anyone seen a price for the stock Yokohama ADVANs?
BTW - some good info in this thread!
An oldy, but a goodie...
https://www.evolutionm.net/forums/sh...227#post268227
Gettin' tired of repeatin' myself...
JW
JW
If you can lower your wheel and tire combo by 3lbs per wheel, the difference is very noticable.
Remeber when you go with light wheels, you should also look at the weight of your Tires. Toyo has pretty good specs on their tires at their website, and their tires are pretty light(T1-S)
Also, when weighing old tires, the tread lost could be up to 6lbs. So thats not a good test
