Lightest Wheels in 17"
simple and classic choice, as well as cheap!!!
KOSEI K1TS... Cost less than 200 dollars per wheel, you can find them everywhere and they weight 15.5 pounds... Price/weight ratio they are unbeatable!!!
Hey thats the sunoco right outside cross county sears right?i took a pic there too almost at same spot lol
Go to www.wheelweight.net
Where did you buy them? I haven't seen 17x7's so far I've seen is 17x7.5
RPF1 17x7 is lighter a little bit(~13lbs). Also needs a spacer in the front
I love my Rays Gram Lights 57F, in 17x8.5 30mm offset.
I've hit a curb at 40mph, it damaged my lower arm, but my wheel survived it with just a ding.
It is worth it in my opinion to have a true forged wheel compared to semi forged or cast wheel.
I believe they are about 17lbs each, compared to 21lbs for stock.
I can definitely feel the difference in weight when i switch between them from winter to summer.
The suspension is able to react to the road a lot better obviously.
See:
http://www.tirerack.com/wheels/gramlights/gram-lights-wheels.jsp
