Help! My alignment is all off!
well let me add my 0.02, if it was improperly installed with the steering wheel, heres a simple way to check stop have your steering wheel up right straight. Turn the wheel to end remember where it stopped. Bring it back to middle, turn wheel opposite way till stop. The wheel at stop either side should be even, or else your steering wheel was not installed right, if not installed right one side will turn more/less then the other shop. Aligning it would be like putting a band aid on a broken limb that broke through the skin, its covering an issue. If thats the case, take it back. If not, best bet is to shake your front end down, use 2 people. One shakes at 12 and 6 o clock for play in tire/wheel, other person looks underneath and watches for movement at the spindle/hub. Then shake tire at 3 o clock and 9 o clock position, other person watches tie rods, watch for any kind of popping or excessive movement. No matter what dont use eye ball method for adjusting toe, flat pavement, and a kit is needed if you go cheap in that matter. If your toe is out .5-1.0, might not be enough to visually see, till your on secondary rubber with cords almost showing in a little bit of time.
not necessarily, usually what happens during the steering wheel install, is that steering shaft couldve been maybe a tooth or two off when installed, usually for example a similar issue is when your rack and pinion is replaced, and theres a tool that holds your steering wheel in place, because the shaft could move and if it does, could cause uneven end to end turning. Your complainin about it to the wrong people, call them tell them to check it again, explain your concerns, usually shops have no problem rechecking there work.
It's been awhile, long while, if they weren't gonna do it then for sure they aren't gonna touch it now... It drives perfect when the steering wheel was replaced crooked.
Based on what I've read in this thread, I'm not sure this belongs in the "Advanced" section of the forum.
The EVO is well known for having excellent steering response, so isn't "super sensitive" normal? As for "turns super funny" and "pull weird," well, you'll have to be a bit more descriptive than that.
I assume that's a view from above, looking down on the car? If so, that means the right front wheel has toe in, which can be fixed with an alignment.
Based on what you've described (or not described), I'm not sure you should be certain about anything. dastallion's suggestion will take you all of about 30sec and might prove whether the steering wheel is actually installed off center or not.
Or you might consider starting a thread with a more descriptive subject to get some steering gurus in here. I imagine there's someone on this board who has removed their steering wheel and can tell you whether it will only go on in one orientation, or if it's splined such that it can be installed in any orientation. Unfortunately, that someone might not open a thread with a subject like "Help! My alignment is all off!".
I think he'd be better off replacing step 2 with "get an alignment." He (apparently) hasn't done so since early 2007, so it's not too surprising that the alignment isn't spot on.
I know what an evo should feel like. I drove it before I replaced the steering wheel. My brother had an evo that we compared too and mines was definitely "off". Turning the wheel in one direction requires a bit more strength than the other, though if I let my hands off while center, it'll stay straight... I know it's suppose to be sensitive but it seems its more sensitive towards the right.
sorry for the thread jack but i did this test tonight and my steering wheel turns about 20 degrees more to the left than to the right. and i noticed my passenger tire is rubbing on the inside of the wheel well .when im in full lock.
Did you have your steering wheel replaced?
im going to put my .02 cents in and take this from someone who does alignments on a daily bases. If the problem started right after alignment was done, than the shop must of not performed the alignment correctly.
Even if the steering wheel was put back together 1 or 2 splines off it shouldn't have thrown the alignment off the way your describing it except for the steering wheel being slightly off centered. While doing the alignment, it would of been a very minimum adjustment to be made on each side of the toe to adjust it back, so i doubt the problem lies where the steering wheel was positioned.
I agree with what people have been replying stating that they "band-aid" the job by trying to suck you into doing an alignment, theres no doubt about it. There should of been no reason to do an alignment if the car drove fine and all you needed was the wheel replaced.
if the shop knew what they were doing, and they were careful and centered the wheels prior to removal of the wheel, you wouldn't have an off centered steering wheel
I would recommend you to go to a reputable alignment shop to get the car checked out and ask for a print out.
If your steering rack isn't centered (wheel off by one spline), you will never have a perfect alignment.
JoeDirtSUCKS
Apr 15, 2014 09:14 AM
Ralliart367
39
Jan 29, 2013 07:37 AM
taylorgang
12
Feb 18, 2012 11:59 AM
Poloiceberg
Jan 23, 2011 07:01 PM
nala
Jun 11, 2009 06:22 AM
