need advice about tire choice for drag
Old Mar 10, 2012 | 01:02 AM
4ukc's Avatar
need help plz about tires I am about to choose smth for a good grip
the choice is between:
1)BFGoodrich g-Force T/A KDW 2 255/40/17
and
2)Dunlop Direzza Sport Z1 Star Spec 255/40/17
may be someone can advice me smth better
thanks
Old Mar 10, 2012 | 05:05 AM
sparky's Avatar
Originally Posted by 4ukc
need help.....about to choose smth for a good grip.....2)Dunlop Direzza Sport Z1 Star Spec 255/40/17...may be someone can advice
The Direzzas are sticky but just keep in mind about sizing that they can run a bit wide. Will you be mounting these on the stock rims?
Old Mar 10, 2012 | 07:05 AM
4ukc's Avatar
no I got CE28 17x8.5 ET32
Old Mar 10, 2012 | 02:18 PM
CT9Asphixyation's Avatar
I have no personal experience with the bf goodrich. However I ran the Dunlops and was able to pull consistent 1.6-1.7 60' on a track that has poor prepping. You wont be disappointed.
Old Mar 11, 2012 | 11:31 AM
4ukc's Avatar
what size do you use?
Old Mar 11, 2012 | 07:00 PM
TigOLDBiTTies's Avatar
if these are going on a set of wheels just for drag then i would not use either of those because of the harder sidewall. usually harder sidewalls mean more wheel hop and that is not good for the drivetrain.
i would go with et streets because of the soft sidewall and great grip.
now if your using it every day and you daily drive the bfg drag radials are pretty sticky with a softer sidewall.
Old Mar 12, 2012 | 07:49 AM
Neal@tirerack's Avatar
Agreed. If these are strictly for drag use then you should get a proper tire that will deflect under load. A street tire really doesn't have the sidewall construction you need.
Old Mar 12, 2012 | 01:43 PM
4ukc's Avatar
the point is by the rules of my class here in Ukraine I can`t use ET Street slicks. the only tires aloud are DOT and E. In case I use slick it should have longitudinal and paralleled protector (I am sorry I dont know exact translation from Russiam) but can you advise me a set of tires if ET are not aloud plz?
Old Mar 14, 2012 | 12:03 PM
4ukc's Avatar
bought BFGoodrich g-Force T/A KDW we`ll see how it works
last year I had Nitto Invo for DD its great but for drag it is usless
it_manager
Dec 22, 2016 10:55 AM
Skidonner90
For Sale - Wheels / Tires
Dec 18, 2015 07:20 PM
memphis69
Jul 18, 2015 10:10 AM
artinist
Mar 7, 2013 12:02 PM
dangle
24
May 8, 2012 09:50 PM
