Brakes are squeeking, Anyone else?
Old Jan 20, 2004 | 06:19 AM
Gobi's Avatar
Well guys i just bought my EVO about two or three weeks ago and I've noticed over the last week or so that the brakes are squeeking pretty badly when I come to a full stop. Is this something that the EVO's just do or do I need to take it in?
Anyone else have this problem?
Old Jan 20, 2004 | 06:20 AM
wmcorcor's Avatar
Mine has been doing it more in the cold weather. It squeals right a sthe car is about to stop, especially at very low speeds. It comes and goes for me...seems to be worse in the extreme cold.
I have about 7K on mine.
Old Jan 20, 2004 | 06:42 AM
BaLListic_EVO's Avatar
seems pretty common mine does it and it was kinda expected.... its all good though
Old Jan 20, 2004 | 06:48 AM
Smogrunner's Avatar
Mine went throught the same phase. I think I glazed them or something showin off to friends how well it stops. Anyway, they stopped squeaking after a couple of weeks and never came back. No worries!
Old Jan 20, 2004 | 06:52 AM
Gobi's Avatar
That's a relief. I was starting to think the Brembos were in trouble.
Old Jan 20, 2004 | 06:55 AM
OnlineAlias's Avatar
Big brakes like the Brembos do that...the bigger, the harder it is to dampen the squeel (which is just a harmonic vibration).
Nothing to worry about..like everything else it is something you have to live with to get the insane performance...
Old Jan 20, 2004 | 06:58 AM
brwnrice's Avatar
it is a common norm for a high performance brake pads do that. mine are squealing too right when i'm about to stop. Even my buddy with an sti has that same symptom
Old Jan 20, 2004 | 07:08 AM
sr20det91's Avatar
Very common and normal, espicially when its cold outside.
Old Jan 20, 2004 | 07:09 AM
lowkey's Avatar
Registered User
Re: Brakes are squeeking, Anyone else?
Seems to be a very common thing, mine was doing the same since new and it now has 1,800 miles on it. There are different pads that apparently would help and also would make lesss dust.
I like this place, one of their engineers also post here sometimes:
http://www.carbotecheng.com/bobcat.htm
Old Jan 20, 2004 | 07:53 AM
illt3ck's Avatar
I'd recommend bedding in the brake pads and rotors, just like any other brakes installed on a car.
Old Jan 20, 2004 | 07:55 AM
Gobi's Avatar
What exactly is bedding in, referring to brake pads and rotors?
Old Jan 20, 2004 | 08:06 AM
en1gma19's Avatar
Try a search. This topic has already been discussed several times.
https://www.evolutionm.net/forums/sh...t=brake+squeel
https://www.evolutionm.net/forums/sh...ht=brake+noise
Old Jan 20, 2004 | 08:36 AM
illt3ck's Avatar
taking the car up to 65mph or so and slamming on the brakes (watch your abs work) (be safe) that way the pads and rotors can intermesh properly Right now its flat surface against flat surface, hence the squeeking.
Old Jan 20, 2004 | 08:55 AM
hueman's Avatar
i always take the squeeling as a warning to everyone of my coming
Old Jan 20, 2004 | 08:57 AM
chico's Avatar
Normal
Don`t worry about it mine did the same, just take it to the track and you will never hear it again. Your car will thank you for it!
Chico
