Tein Pillow Ball with Variant 3?
Old Mar 25, 2012 | 06:28 PM
eaneumann's Avatar
I have a set of KW Variant 3's on there way and I'm looking for a set of pillow ball mounts for them. Suggestions?
Will these fit? Super cheap...
http://www.sportcompactonly.com/Mits...02_vy-2003.htm
Old Mar 27, 2012 | 05:58 PM
eaneumann's Avatar
Bump...
Try'd to search, couldn't find the exact answer I was looking for.
Old Mar 29, 2012 | 09:47 AM
JDMevoBOOST's Avatar
Contact AMR. They might be able to make a custom set for you.
Old Mar 29, 2012 | 12:41 PM
Dallas J's Avatar
Veteran: Army
No clue on the shaft diameter, but in a pinch those will work. The plates on the Tein plates are pretty thin, but they look damn near identical to the Cusco plates I saw.
I have a set (as much as I hate tein), that I put on temporarily for added camber on the bilsteins before I got my real setup. Now they live life on my GVR4 with a full evo suspension swap bolted in thru re-drilled holes. The bearing actually feeles pretty beefy, and so far they havent gotten sloppy. So for a cheap upgrade to some adjustablilty, Id say go for it as long as the shaft on the KW V3s is the same diameter as the stock struts. I would guess they are since they work with stock hats, YMMV.
Old Mar 29, 2012 | 12:42 PM
Lazyfong's Avatar
I would get the Vorshlag camber/caster plates, they are expensive but check out the specs.
http://www.vorshlag.com/product_info...roducts_id=299
Old Mar 29, 2012 | 06:03 PM
eaneumann's Avatar
What does Vorshlag recommend for the rear? I have new OEM mounts on the way for now.
Old Mar 29, 2012 | 10:35 PM
Lazyfong's Avatar
I am not sure, you should see what they recommend.
I_want_MR
Jan 5, 2016 03:49 PM
McSlides
Nov 9, 2013 12:26 PM
chrisff521
Apr 12, 2012 09:04 PM
DrivelineSales
EvoX 'For Sale' Suspension / Brakes / Handling
51
Aug 4, 2011 06:57 PM
ForcedFedRS
44
Sep 19, 2008 05:40 AM
