What to do why doing coilover install
Im getting coilovers soon as well as new front Ball Joints. I want to know if i should do anything else why i have the old shock out before i put the coilovers in?
you can do the rear bumpsteer as well, cause you need alignment after doing it.
might as well knock it out and save from another alignment.
off topic but you have some horrible grammar. "why" when you mean while.
I usually would leave you to research that, but I'm bored in my hotel room...
http://www.oakos.com/Merchant2/merch...ory_Code=25800
all of the above + rear trailing arm bushings. http://www.whiteline.com.au/product_...t_number=W0594
Might sound stupid but brake lines and a brake service might not be a bad idea, if you haven't already done so. I know you don't have to remove them to do coil overs, but it should save you time/labor in the long run. The bill looks like it's already getting up there though
quality suspension isn't cheap.
