An effective way to add caster?
I installed CT9A camber plates on my TME, they sit the same as shown in this pic. It seems I can get some caster and camber. I also set the stock camber bolt at the 2 degree setting. Looking for some opinions, can this be considered an effective way to add caster?
Yes, you can add caster that way but not really with that plate. Problem is you aren't getting much further back than the stock location. What you are giving up is the ability to fine adjust your camber though. I use to have my hats which have more adjustment like that, but when setting camber it was just much easier to get L/R equal when I didn't have to play with the slop in the camber bolts.
GTWORX.com
83
Dec 30, 2016 05:15 PM
Dallas J
Oct 28, 2016 05:59 PM
kzlflash
10
Oct 14, 2012 07:41 PM
