Help with slight noise please.
I need help, I have a slight noise coming from what seems to be the front driver wheel. Its hard to describe but the noise sounds almost like a rock stuck on the tire. It does the noise once every full tire rotation. The faster I go the and the faster the tire spins the faster the noise occurs. While coming to a stop the noise starts slowing down. No noise happens when I'm at a stop. The noise almost sounds like chuh chuh chuh chuh.
Thanks in advance.
Thanks in advance.
Check and see if anything is rubbing on the brake dust shields or any other component around the hub area. I'd also jack it up and check the wheel bearing just to be sure (you would notice this more when turning though).
deegaw11
11
Oct 3, 2009 05:25 PM
Evo Tengoku
Nov 12, 2008 10:49 AM
