Need help. Grinding noise.
I have a grinding noise coming from the driver's side front wheel. Sounds like metal to metal grinding/chaffing. Only happens once per wheel rotation. The faster I'm moving, the faster the noise. Already bent back the dust shield. Noise didn't go away. Installing new brake pads (wear markers?) this weekend. Is there anything else I should check for?
Check for wheel bearing play. Sit down in front of the wheel (chest towards the wheel) and grab the rim or tire. Shake the wheel forward and backward. If there is play or a noise - have the bearing checked. I say bearing, but for our cars its part of the wheel hub.
king_cas
Jul 15, 2016 08:57 AM
king_cas
Jul 9, 2016 10:13 PM
