Rotorpro + Brake Man 93's
Hit 77k miles, and my rotors were getting pretty bad. Lots of wobble and shuddering while braking.
Went with dimpled+slotted rotor pros, fully coated black. Brake man #93 compound pads.
The previous owner had ferodo pads put in, I don't know when. The rotors were not changed as far as I could tell, unfortunately, so the pads were getting chewed up by the rotors. They still had some decent life left on them, although the front passenger pad was starting to crack and separate from the backing.
Just hit ~100 miles on the new setup, so they should be fully bedded in by now. Initial impressions are very good with this setup. Pads squealed quite a bit in the beginning, until the coating on the rotors was fully worn off. Nothing to speak of now. Just the usually whirring noise from having pads like these, with dimpled+slotted rotors. I've seen some complaints of the brake man pads squealing, but I haven't experienced that. Liberally coated all sides of the pad with copper anti-seize, so we'll see.
The brakes bite aggressively , but not overly so, braking is very predictable and linear. Pedal feel is good, no pulsating or shudder at any speed or level of braking effort. Haven't had a chance to push them very hard for extended periods of time, so I can't comment on how they fade with use and heat. I'll update after I get a chance to do so.
To summarize, so far, love this rotor and pad combo. Noise is minimal, braking is better than the old slotted+cross drilled rotors with feredo pads. Also, bled and refilled with ATE super blue. Old fluid looked like generic DOT3/DOT4 fluid, was very good color though, didn't look like it had boiled or burned.
I've clocked around 1500 miles on 'em so far, and they've been working great. My initial impressions are still the same now, I have noticed that the dimpled rotors make more noise than the cross drilled, but that's to be expected.
I love 'em.
I love 'em.
Smike
63
Apr 29, 2019 07:27 AM
adamsrotors
Vendor Classifieds
24
Jun 17, 2013 05:28 PM
Shaker Motorsports
Evo 'For Sale' Suspension / Brakes / Handling
28
Oct 13, 2005 07:02 AM
Gruppe-S
Oct 8, 2005 12:38 PM
Thwack
Jul 20, 2004 06:30 PM
