Brembo Calipers need help asap
Old Jul 10, 2012 | 12:18 PM
projektevo9's Avatar
Does anyone know the size and thread size of the bolt that bolts the front calipers to the knuckle? I want to say the head is 19mm but I'm unsure any help would be greatly appreciated.
Old Jul 10, 2012 | 12:36 PM
mouseIX's Avatar
I'm pulling my track pads off in about 2 hours. I will post dimensions.
Old Jul 10, 2012 | 12:44 PM
M00kiE's Avatar
mitsubishiparts.net should have exploded assembly drawings of everything on their site. They might have it on there. If not, give them a call and i bet they can tell you.
Old Jul 10, 2012 | 02:40 PM
mouseIX's Avatar
19mm head. M12 x 1.75. Thread length is 35.3mm. The washer is 3.3mm thick.
Old Jul 10, 2012 | 03:10 PM
Thank you sir
Old Jul 11, 2012 | 06:07 AM
Another question related to these never had to pull the pads, do the pins in the side release? How do you get these out?
Old Jul 11, 2012 | 06:17 AM
Kracka's Avatar
Tap them gently with a small punch and hammer and they'll slide out.
Old Jul 11, 2012 | 06:42 AM
mouseIX's Avatar
^^^this. From the outside of the caliper.
Old Jul 11, 2012 | 08:44 AM
Thanks guys much appreciated
Old Jul 11, 2012 | 08:54 AM
There has to be more to it than just punching the pins out?
Old Jul 11, 2012 | 09:04 AM
mouseIX's Avatar
You might have to push back the pads a little to push the pistons in. Then just pull them out the top. Make sure to pay attention to the orientation of the shims on the back of the pads.
Old Jul 11, 2012 | 05:33 PM
Got them out thank you sir
Old Jul 13, 2012 | 08:05 PM
WRC-LVR's Avatar
Nope there is not...however make sure you fully seat them when installing. Nothing quite like losing a pin at high speed
