RPF1 Question
RPF1 Question
Good morning gentlemen. I've researched a good bit but have found inconsistent results with RPF1 options.
I've decided on 18x9.5 +15 with a 245/35/18 Federal 595
My question is if I buy 18x9.5 +38 in the rear will that look goofy or different. I'm lowered on JIC coilovers and would like to keep the ride height similar to where I am at now. What are your thoughts?
Current setup picture:
I am running a 17x9.5 +18 and +45 I have a little bit of poke in the front but it is pretty flush in the rear. I will try to get you some pics later today. It really is not that noticeable due to the way our fenders flare out.
Dude. Why u no ask me about this?
+15 will be too aggressive in rear for 245 tire. +38 will be fine. Or get a set of all +35-38 and run extended studs and spacers in front. That way wheels and tires can be rotated easier.
Sack up and run 265 or larger!
Why not just run +38 all around with extended studs + spacers up front? As mentioned above, this setup allows you rotate your tires without unmounting and remounting them.
Also, definitely run either a wider tire unless you're running in a 245-width limited class.
17x9.5 +38 RPF1s with a 20mm spacer up front is a popular and proven combination.
I would grab +38 all around like mentioned above. Much easier to deal with, and your effective offset will be around +18 in the front after spacers.
If you throw a 10mm spacer in the rear and a 20mm in the front I think you will achieve the look you want.
My setup now (NT03s) consists of 18x9.5 +27 in the rear and +17 in the front on a 265/35.
nor11384
13
Jul 20, 2016 05:33 PM
WTB[MidWest]: WTB: Black 18x9.5 Enkei RPF1
RedEvoxGSR
For Sale - Wheels / Tires
Feb 14, 2016 11:28 AM
FS[West]: Enkei RPf1's 18x9.5 +15, gunmetal
Kidloco51
Jan 8, 2015 08:49 PM
