MR Billsteins Replace or Repair
So no additional commentary needed as to the superiority of the OEM MR Billsteins...
Other than they look like garbage after 6yrs and 100K miles of all condition driving in the North East, if I'm looking to do only a mild set up are they worth trying to restore or should I just bite the bullet and source a fresh set of four?
I know alot of members buy them second hand with lower miles on them and send them out for service, but the lower models that I've seen pix of in the for sale forums all look better than mine do!
Can you live without them for a little while? I would expect a turn around to take up to 2months (I could be wrong)... Do you use aftermarket springs or other suspension mods or you just want them restored to OE specs? A buddy of mine repainted his before the rebuild and they look great.
I would take all these things into account when making your decision.
Bilstein charges $75/shock to rebuild. Its not as costly as buying a new set for the dealer, or try to source out the ever elusive HDs. Turnaround has been abour 2-3 weeks last I checked. Its a good alternative if you can afford the down time, and want to retain what you have.
Yeah, that's part of the problem... it's my main driver. So right now I can't afford to have it sit. I don't drive well enough in competition (yet) to warrant coilovers but if you do the math:
New Billsteins: $2000
Swift Springs: $300
New mounts front and rear: $500
For $2800 I could get KW Var. 3s or for a few hundred more the top dog Ohlins. Then have the freedom to adjust to whatever stupid wheel configuration I get into later. Getting a custom alignment is a wash, around here it's either cookie cutter or full custom.
I'm having a tough time justifying the costs of 'redo'ing the stock struts.
I know most basic dampers out there can't compete with the Billsteins but from what I'm reading there are some at the top level (inc. the ones mentioned) that can.
Swift Springs: $300
Before a few weeks ago when I got active on the board I thought I was going to get some Tien's All I knew was my current struts were in need of replacement.
Again thanks to EvoM for helping me avoid a mistake!
Nah, my mind is far from made up! There is no clear choice for me... so I'll debate it untill the snow thaws. Either way I don't think my current Billstein's are salvagable. In a couple weeks life will slow down a touch and I'll get under there and give them a good once over. Who knows, maybe a resonable set of used ones will appear by then too.
- Andrew
I'll try to snap some pics this weekend and add them to the thread.
For all intents and purposes they are the same - and if you're thinking about going to Swift springs, then the HD valving is probably slightly better than the stockers.
As an alternative, to keep you driving, you could always source a set of used KYB shocks to slap on the car while you're waiting for the Bilsteins to be rebuilt. Should be able to source a set of KYBs for next to nothing - that'll keep you motoring and will really let you appreciate the Bilsteins when they're back on your car.
l8r)
l8r)
- Andrew
wiggam11
19
Oct 21, 2013 12:06 PM
luvboost
31
Apr 8, 2011 11:04 AM
Raceghost
Jul 3, 2009 12:49 AM
HeRtYIXMR
13
Dec 22, 2007 11:53 AM
