Need help with brakes.
changed my rotors and pads back in June. Well been driving for a while looked at my rotors have slight grooves and what looks like uneven wear. What gives is my? I bleed them right. this was the reason i changed them when i bought the car. Should i re-bleed them or start looking for new front Brembo Calipers..
The second pic is the drivers side shows a little but not bad. when i first did the brakes i checked them for the first two weeks and i got nothing. i only DD this car so im not sure. I have the old rotors still so im thinking about taking them to cut and re-install and re bleed. Might change the pads too. i think they are still covered under warranty.
Bleeding isn't going to fix a rotor - pad problem. Unless you have a stuck piston, changing calipers won't fix it either. It is hard to tell how bad the rotor wear is from the picture. But if it is bad, you have either crummy rotors or pads, maybe both.
You went cheap but you still paid money for the rotors and pads. So, you might as well get some of that investment back. I'd suggest just running them for now while figuring on replacing them with better equipment later.
Get better pads.
How deep are the grooves? Can you feel them with your finger nail? Is there any brake shuttering under braking?
Did you re-use the stock rotors when you change pads? Or are they both Autozone pads and rotors? Did you have the rotors turned before the new pads?
Get better pads.
From what you said the only thing wrong is the appearance right? If the car stops well and the brakes don't howl like a banshee drive the car, enjoy it and don't look at the brakes, you have absolutely nothing to worry about.
