Is an alignment needed after height adjustment?
Old Nov 25, 2012 | 05:12 PM
shrtstuff89's Avatar
I just installed some awd spec d2 coils today, and i know i need an alignment done. Say however, if after driving for a week or so, i realize the height needs adjusted up or down up to an inch, do i need another alignment after that too?
Old Nov 25, 2012 | 05:16 PM
llDemonll's Avatar
yes
do all your adjustments now, then get an alignment.
Old Nov 25, 2012 | 06:01 PM
ReidFletcher's Avatar
If your really serious about getting the full performance out of your coilovers figure out the ride height you like then have it corner balanced then aligned.
Old Nov 25, 2012 | 10:11 PM
the_evodude's Avatar
like everyone said, you should get one after an adjustment
Old Nov 26, 2012 | 07:32 AM
elim0's Avatar
as said above, do all adjustments until youre happy with height then get alignment.
adjust height, drive around, let it settle a bit, check until youre happy, but dont drive around for too long without alignment. more important for front wheels, rear adjustment wouldnt affect alignment as much but still settle for a height then get alignment.
i wouldnt worry about corner balance unless your racing the car imo
Old Nov 26, 2012 | 09:18 AM
ILuvJDM's Avatar
corner balance is a waste of money unless you race the car
Old Nov 26, 2012 | 09:27 AM
Gordian79's Avatar
Corner balancing is useless on a street car.
Old Nov 26, 2012 | 05:40 PM
eug!'s Avatar
Yes
Old Nov 26, 2012 | 05:58 PM
Got my good gap in, bout a finger and a half gap. Plan to do the firestone lifetime alignment. I do not race it more than the few drag visits a year i plan to do.
Old Nov 26, 2012 | 06:09 PM
Drew1's Avatar
Watch out, most "lifetime" alignments are to factory settings.
Old Nov 27, 2012 | 12:30 AM
^^ yah, make sure they allow custom alignment specs before you sign up for their lifetime alignment
Old Nov 27, 2012 | 03:35 PM
feet2017's Avatar
most definitely
Old Feb 9, 2013 | 08:54 PM
selp's Avatar
Sorry for reviving this.
I just got new rims, tires and about to drop the MR bilsteins on swift springs.
I will use the springs for a couple of hundred miles to let them set,
but I have never done an alignment before.
What should I ask for them to do? The car is a street, daily driver car, with some highway use.
Thank you!
Old Feb 9, 2013 | 08:59 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Thank you!
Just an alignment to OEM spec is all you need.
Old Feb 16, 2013 | 08:03 AM
Ludikraut's Avatar
Factory spec alignment may be all you need, but what you really want is more along the lines of:
0 toe all around
-2 front camber (there are basically two settings -1 and -2)
-1.2 rear camber
l8r)
