wheel bearing clarification
hey guys, so my rear passenger side wheel bearing is growling at me to replace it. I did a few searches, but it's not crystal clear, when I order the new hub assembly, does it need to be complete with studs in it already and all that jazz? Or just the "cassette" bearing pack?
This:
http://www.ebay.com/itm/NEW-Rear-Lef...e1b5e4&vxp=mtr
Or this:
http://www.ebay.com/itm/Timken-Rear-...d314d2&vxp=mtr
thanks for the help!
This:
Or this:
The Timken Wheel Bearing would be the right one to go with. The whole unit should be replaced because that is just like the OEM replacement. Just like pictured here:
http://www.streettunedmotorsports.co...el_bearing.htm
First you have to undo the axle nut and then the four bolts that hold the wheel bearing to the hub assembly. I recommend getting new OEM mounting hardware for the axle. I believe I read somewhere where it was one time use.
That would be a replacement Axle Nut, Axle Washer, and Axle Pin.
Part numbers in order are MB109029, MB109025, and MF472085.
SilverShadow03
May 25, 2012 01:39 PM
