Question about Abs Delete.
What's up guys, I'm considering to get the Rs Abs delete to drop some weight on my GSR. Do any of you Rs guys have any issues Dailying you cars? Anything that upgraded brake lines, systems, etc wouldn't fix? I'm not completely familiar with all that stuff. I was under the stupid impression that my car would slide even with the slightest bit of braking, as I commute on the highway quite often. If you guys have any information to share, I'd appreciate it. Lol, I know it's kinda dumb and random but I'm just curious.
Thanks!
Thanks!
Depends on driving conditions. If your on dry clean roads and are not braking violently your car should perform as usual. Driving on snow and ice packed roads will be a little more challenging. You might have to pump the brakes as abs would do automatically.
Thanks guys!
The negative about ABS on snowy roads is the sensors continually pulse because because the tires are on a slippery surface. Without ABS, you can brake and get through a layer of snow where there is a bit more traction and you will stop sooner. ABS doesn't stop you faster, it allows you to steer while braking....in snow it REALLY extends your braking distance.
hyperscott
11
Apr 2, 2018 02:24 AM
badev0
Nov 13, 2015 05:51 PM
