cheap brakes??
Old Dec 24, 2012 | 04:56 PM
cfdfireman1's Avatar
So "BRAKES" are a cosmetic upgrade for you?
Old Dec 24, 2012 | 05:11 PM
deadstockkpomp's Avatar
no, but if i can have them look good might as well. The color option is available. My main question here is..Will this kit come with all the rotors and pads? It does not say "front and rear" rotors but it says "front and rear" pads...
Old Dec 24, 2012 | 06:02 PM
WikdEvo's Avatar
email the company and before you buy slotted and drilled rotors, do some research.
Old Dec 25, 2012 | 10:28 AM
finally made my order today. did a bit of research the brakes i got were rotorpros (slotted) with gold zinc finish, and front and rear stoptech pads.
Old Dec 25, 2012 | 06:34 PM
tell us again why do you think you need new rotors?
Old Dec 25, 2012 | 06:37 PM
Im starting to dig into the rotor a bit in the rear and the fronts just about there, and my brake pedal feels really soft (no grab)
Old Dec 26, 2012 | 07:38 AM
change the front pads before they "dig into the rotor" there's no reason to change rotors that are within spec unless you just want to spend your money. you should be able to change pads all around on an evo in about 1/2 hour with the right tools. you may as well change the fluid while you have the wheels off it's a much neglected maintenance item.
Old Dec 26, 2012 | 09:09 AM
1hotevo9's Avatar
look at this...
http://www.cquence.net/
http://www.cquence.net/ymm/product/l...nginetypes=all
cheap and good
whoppa
10
Aug 7, 2013 12:54 PM
zbents
Jan 19, 2013 05:47 AM
ProfessorX
Sep 5, 2011 06:17 PM
PFC Brakes
Nov 17, 2010 02:23 PM
JuniorRSX!
Dec 11, 2005 10:26 PM
