Stuck Coilover locking collar Zeal coilover
Old Dec 27, 2012 | 08:58 PM
EvoBraj's Avatar
Im trying to adjust my ride height on my zeal coilovers. Im having a problem breaking the bottom locking collar loose. Ive tried pb blaster and its still not budging.
I also do not have the wrenches included. Is there a wrench anyone can reccommened to get it loose. Im thinking i may have to remove all 4 coils and use a vise to break them loose.
Heres a picture of what im having a problem loosening.
Attached Thumbnails Stuck Coilover locking collar Zeal coilover-dsc03128.jpg
Old Dec 28, 2012 | 12:24 PM
EvoBraj's Avatar
any ideas??? bump
Old Dec 28, 2012 | 12:32 PM
evo8dreamcar's Avatar
When ever I adjust mine without the wrenchs i use a flat head/pry bar and a hammer as it just needs to be loosened
Old Dec 28, 2012 | 09:24 PM
EvoBraj's Avatar
yea i tried doing that, with no luck, the entire coilover just starts unscrewing if that makes any sense? Im thinking i may have take the coils off and have the collar replaced or try to use a vice to get it loose.
Old Dec 29, 2012 | 08:14 AM
snafufx's Avatar
My Zeals did the same thing when I tried to adjust them. The hammer trick basically unscrewed the entire coilover, not the "sleeve". Needless to say I left them alone. If you find out how to do it, please post a follow-up because I want mine raised a bit. Good luck.
here's my post if any of this helps:
https://www.evolutionm.net/forums/ev...nction-xs.html
Old Dec 29, 2012 | 08:27 AM
EvoBraj's Avatar
Will do! I may just end up taking all the coils off and cleaning them all up when it gets a bit warmer in the spring, unless i can find a heated garage to mess around with them in some more.
SpeedI2acerX
Aug 22, 2015 10:07 PM
EvoBraj
Dec 24, 2012 03:34 PM
EvoBraj
Aug 13, 2012 09:24 AM
Charlie-Y
Apr 6, 2011 06:00 PM
2StepsAhead
Oct 19, 2006 04:46 PM
