Camber kits
Don't make me come back in here! tee hee
Camber plates are only for the front. In the rear, the angle of the shock is only relevant to the motion ratio because it's multi-link. There's no such thing as a rear camber plate for our cars. Try to wipe that ad from Import Image from your mind.
Too my understanding all camber plates do, Is allow you too adjust your strut for more clearance do to adding more camber. Reason I'm stating this is because it seems to me as if the OP is a bit confused as to what camber plates actually do. Also like other people stated I have yet to find rear camber plates for our vehicles. Everyone that is running aggressive wheel and suspension set-ups tend to just replace the trailing arms in the rear. After market camber bolts should be what you need for more camber since that's what your looking for. I my self haven't gone that route yet and can't decide on what wheel setup I'm going with, so don't really know who sells what camber kit but hope this helps a bit.
Please be precise. I don't have an 8 or 9, but I'm pretty darned sure that the training arm does not get replaced. The lower lateral arm (aka track arm) and the toe arm get replaced. The trailing arm and the upper A-arm do not.
From what I've researched for 8/9 our trailing arm is what gets in the way of us running 10 or higher with a good amount of meet on your tires. Unless you run the hellafagg stance your gonna need that and among other things I.E. spacers,coil overs, more - camber rolled and pulled fenders, fender mod up front. This all ofcourse depends on wheel sizes and offsets. What do you drive?
if you're running 315's sure, the trailing arms will need to be replaced, but that's not an issue for people will the "stanced" look like OP is going for
also, as his sig says, he has an X
I could have swore I stated depending on if he's going with the hellafagg stance.......
Technically the OP didnt even specify really if he would be running wide tires also. And if hes trying for the look or stance in that pick they look pretty beefy to me but anyway hope all this helped a bit.
TouringBubble
62
Aug 7, 2012 09:57 PM
AutOtaku
Feb 24, 2012 11:35 AM
