caliper seals between halves
Old Jan 9, 2013 | 08:18 PM
hatesposers's Avatar
Has anyone found a source for the seals between the caliper halves?
I couldn't find anything with a few searches.
Old Jan 9, 2013 | 08:24 PM
Detective Coating's Avatar
There are not any replacements currently. A friend of mine and I are working to get ones made to OEM specs. You cannot use any old o-ring from Autozone as they will quickly deteriorate with the brake fluid and heat cycles.
Old Jan 9, 2013 | 08:39 PM
do you have any ETA on this?
Old Jan 9, 2013 | 09:06 PM
No I do not, we just started searching for manufacturers and talking to them about the requirements we need for them. I'll post back when I know more.
Old Feb 14, 2013 | 11:29 AM
I just ordered a large quantity of replacement seals as that's the only way they make custom orders. They should be to me late next week. They will be $15 shipped for 2 of them.
Old Feb 15, 2013 | 06:37 AM
Ok. What materials are these made from (complete specs)? How many seals are there per caliper? Are they the same size front to rear? How much for a full set to do all four calipers?
Thanks
Old Feb 15, 2013 | 07:20 AM
Thanks
They are made of EPDM (brake fluid safe) they are the same size as the oem ones which I believe were 2mm thick x 7mm id x 11mm od. This is just for the 2 rear o rings between the caliper halves. The dustboots and piston seals you can order from girodisc which are around $160 shipped.
Old Feb 15, 2013 | 08:55 PM
OK, so it's 15 per caliper (2 seals per caliper)? so $60 for all 4 calipers. Are the sizes the same for the front and rear calipers?
Old Feb 16, 2013 | 05:08 AM
No there is 1 o ring in each rear caliper for the fluid to transfer from one half to the other. The fronts transfer fluid with the 2 crossover lines. Girodisc has all the other seals you need which are the dustboots and piston seals, rears are $24 and front kits $48 which you need 2 of each kit.
jingalalahoe
Sep 9, 2016 12:44 AM
wazmunstr
Nov 6, 2015 09:26 AM
SSGSXR
Jul 30, 2015 06:01 PM
turbotaloon95
24
Jul 28, 2015 07:47 PM
wing965
Apr 19, 2012 11:27 AM
