Brembo seal advice?
Old Apr 17, 2012, 10:24 PM
wing965's Avatar
Brembo seal advice?
this winter i decided to powder coat my calipers and instead of sending it to someone like TCC for $450 i decided to do it myself locally to save some money...this turned out to be a horrible idea and i am now $700+ into this project and still have headaches...
i am having troubles with the o-ring seals on the inner part of the caliper on the larger piston, does anyone know any tips or tricks to do this without tearing the seal...ive gone through 4 sets of seals already and dont know what else to do
Old Apr 18, 2012, 11:25 AM
wing965's Avatar
bump
Old Apr 19, 2012, 11:27 AM
tsi90awd's Avatar
Hi fellow Michigander:
What exactly is the problem? Is the seal tearing when you insert the piston? I rebuilt my calipers a while ago and don't recall having any problem like that. Make sure you lube the seal/piston/caliper well with brake fluid before inserting it. It might help to twist the piston as you insert it in to the caliper. I recall also smoothing down any sharp edges with very mild abrasive cloth (crocus cloth).
Raptord
28
Jun 22, 2018 08:06 AM
jingalalahoe
Sep 9, 2016 12:44 AM
stunna2o1
Jan 25, 2016 07:02 PM
JonGonzo
Jun 27, 2015 12:49 PM
Boost_Inspired
South Region
11
Sep 23, 2010 08:28 PM
Quick Reply: Brembo seal advice?
