rs master cylinder vs abs master cylinder
Old Jan 10, 2013 | 05:12 PM
flyingscot's Avatar
is there a difference? someone told me they are the same
Old Jan 10, 2013 | 05:44 PM
Hey Kevin
Heres a pic of my RS cylinder. I dont know the answer, but maybe you can see if there are any diffs via pic
Maybe some of the EVO heads here know for sure.
Joe
Old Jan 10, 2013 | 06:01 PM
flyingscot's Avatar
thank you Joe,yeah i took a look at mine and they are very different,abs version does not have the two fittings underneath
Old Jan 10, 2013 | 06:37 PM
flyingscot's Avatar
are those proportioning valves on the bottom?
Old Jan 11, 2013 | 01:38 PM
Some one here knows Im sure. Just need the right sort to view the thread
Saw some pics of the standard master cylinder & can see there are no ports under the valve
The guys on MLR would know
EDIT: Read this ad here (You were right)
http://www.streettunedmotorsports.co...ing_valves.htm
Old Jan 11, 2013 | 04:45 PM
03whitegsr's Avatar
The RS bore is smaller as well. I think the RS is 1" and the abs model is 1-1/16", along with not having the 2 ports on the bottom with the proportioning valves.
Old Jan 15, 2013 | 09:41 PM
flyingscot's Avatar
thank you yes i did some research on this ,im going with your boosterless setup 03
Eno-Evo
Oct 13, 2015 10:48 AM
mrg7243
May 11, 2015 05:07 PM
BlowMeOff
Sep 28, 2012 11:55 AM
superflyevo
20
Dec 8, 2010 06:39 PM
Untamed
Jun 11, 2008 10:34 AM
