Where can I get these brackets???
Old Jan 11, 2013 | 11:10 AM
Mistaken's Avatar
Looking for the black brackets that are inside the caliper that holds the pad in place. I tried Russell at MitsubishiParts but no luck.
You can see the bracket in these pics...
Old Jan 11, 2013 | 11:26 AM
Raptord's Avatar
My calipers don't have such plates... What calipers do you want them for?
Old Jan 11, 2013 | 11:46 AM
Mistaken's Avatar
My IX calipers. It may not be the exact same but it's the same idea.
Old Jan 11, 2013 | 01:28 PM
r1concepts's Avatar
Are these the brackets you're looking for?
http://store.zeckhausen.com/catalog/...p?cPath=24_365
They're from Stoptech.
Old Jan 11, 2013 | 01:47 PM
Mistaken's Avatar
No but thanks.
It's the shim or whatever that seperates the pad from the caliper itself. Had a single screw that holds it to the caliper.
Old Jan 12, 2013 | 08:49 AM
Mistaken's Avatar
First post updated. Those are what I need.
Old Jan 12, 2013 | 09:02 AM
Solenoid's Avatar
Veteran: Marine Corps
It appears the photo you posted shows a caliper casting specifically designed for that bracket.
Do our IX calipers have that angled casting feature & the female bolt hole?
Not sure why youre interested in adding a bracket that may not be designed for the IX caliper?
Old Jan 12, 2013 | 10:14 AM
n2oiroc's Avatar
those brackets are on all 8 and 9 brembos, they keep the pad backing plate from wearing the caliper itself. have no idea what they are called or where to get them though. are they just corroded badly or are you missing one? if they are just corroded badly, you can have a plating shop redo them in cadmium or whatever they are coated with. should be cheap.
you can try http://www.fredbeansparts.com/ and http://www.girodisc.com/ for replacements, not sure what kind of luck you will have though.
Old Jan 12, 2013 | 10:15 AM
Mistaken's Avatar
That is in a factory brembo caliper on an 8/9.
Ill try them. Thanks
Old Jan 12, 2013 | 11:27 AM
llDemonll's Avatar
talk to spec-ops or AWDmotorosports; they always have tons of spare parts laying around. ER might also
Old Jan 12, 2013 | 02:49 PM
Mistaken's Avatar
Good call
Old Jan 13, 2013 | 08:05 AM
cfdfireman1's Avatar
Lost one of those on the rear of my VIII. Good luck finding a replacement, I ended up having the caliper replaced under warranty.
Those are wear plates and they're nice and shiny silver when new, not black.
Old Jan 13, 2013 | 08:20 AM
When all else fails. Contact the supplier direct
http://www.brembo.com/en/Contatti/Pa...spx?Contact=05
Old Jan 13, 2013 | 02:03 PM
Tried call Brembo they won't even talk about Mitsu parts.
Old Jan 13, 2013 | 10:30 PM
Mistaken's Avatar
What a pain in the *** this is turning out to be.
