DIY Rotors and Brakes questions
1 Post
Hey guys, I read through the DIY brakes and rotors change thread. The thread is for front rotors. Is there a different way of changing rear rotors? Also, remove/change brake pads before changing rotors? Do I need some caliper reset tool? Finally, what do you use to hammer the pins out during brake change (saw this on a youtube video where a guy is sticking what looks like a nail or something to get the pistons off). Thanks!!
The front and rears are essentially the same process. Just make sure your e brake isnt engaged or else you wont be able to pull off the rotors. You dont need any special tool to push back in the pistons. Keep the old pads in there and use them as leverage to reset the pistons. Lastly, a nail will work perfectly to remove the pins. Honestly its all very straightforward so dont sweat it.
Refrain from filling the master cylinder, if low, until the brake job is done. When you push in the caliper pistons fluid goes to the master cylinder.
To remove the rotor the caliper must come off - two bolts. Don't allow the caliper to hang by the brake line. If the rotor is stuck there are threaded holes in the rotor. Screw in bolts to pop the rotor free.
stunt2
20
Oct 26, 2014 06:19 PM
chendu1280
12
Apr 16, 2013 07:17 PM
ishotphish
Mar 31, 2013 12:12 PM
