Breaking the tires loose
I've added about 40-50 whp to my car since I bought it, and am currently running all-season high performance tires (because of the winter) on my car - specifically the Conti Contact Extremes.
Here's the deal:
I can break all 4 tires loose
around any turn in 1st gear at will. If the road or my tires are wet, it's simply dangerous
to even try when that boost hits!
In 2nd gear, when I'm making a turn or something, if I gun it and the boost hits, I can also break the tires loose
at will and squirt the car sideways briefly.
I've tried a couple times in third (hammering around a corner) but it is not as likely unless it is wet.
My question - are you other guys able to do this?? I want to know if my car is more powerful that most, or if the tread I am running isn't good enough to handle the current power I'm producing?????
Thanks.
Here's the deal:
to even try when that boost hits! In 2nd gear, when I'm making a turn or something, if I gun it and the boost hits, I can also break the tires loose
at will and squirt the car sideways briefly.I've tried a couple times in third (hammering around a corner) but it is not as likely unless it is wet.
Thanks.
the advans are lethal when they are cold, its like riding on ice. I've slipped a few times before warming up the car. All in all, i'd say be really careful, the Evo is one crazy ****
Originally posted by MalibuJack
On a cold day I'd have traction problems with the Advans.. once the tires warm up, they've been good in everything except bad weather.. hehehe..
So, it's not the temp of the tires in this case.
You are breaking loose because the Conti Contacts are really not good tires. Being in-expensive all-seasons, they don't perform like you would like them too in all conditions.
My car is modified.. honestly on a good launch I can break my tires loose under any conditions, but cold pavement and cold tires (not ice, just cold) it will spin easily and catch you offguard if your not expecting it.. Fortunately I don't really get an opportunity to beat on my car when the tires are cold.
Originally posted by dpwurzer
I have dunlop m2 snowtires, i can get sideways at will. and with the advans, its the same way. off camber and boost comes on=sideways. my evo is totally stock.
<----Sumi HTRs
Its very easy to get the back end out and slide a bit going around sharp turns.
Pop the clutch just a bit on a wet/snow covered parking lot and that back end will come right around. The other day I went to that car museum out by Cahokia, the one that used to be a Venture. The entire parking lot was a sheet of ice. I felt like I was figure skating in the Evo doing spins and what not.
