Stupid brake question
Old Feb 10, 2013 | 08:51 AM
latreille's Avatar
I just put new front rotors on my evo and the still seem warped the steering vibrates pretty bad when stoping from high speed, not so much at 35mph. My question is can anything else cause this because my brake pedal doesnt seem bounce around too much. This is my first experience with non floating callipers and am not sure. the front end of the car is tight its an 03 evo 8 Thanks
Old Feb 10, 2013 | 10:42 AM
Gordian79's Avatar
Try balancing the wheels.
Old Feb 10, 2013 | 10:45 AM
grillpt's Avatar
Lots of times people think they have warped rotors when in fact it's uneven pad transfer/deposits that cause the vibration.. Are the pads new as well, did u bed them properly?
Old Feb 10, 2013 | 10:52 AM
TommiM's Avatar
I've seen feathered wear on tires cause this. run your hand over your tires and see if they are abnormally feathered. if the rears don't show this feathered wear swap fronts to rears and go for a drive and see if it goes away.
Old Feb 10, 2013 | 01:09 PM
latreille's Avatar
thanks guys il swap tires and try it.
Old Feb 10, 2013 | 03:01 PM
latreille's Avatar
swaped the wheels around and the first stop was perfect but then it came back on the second stop attempt?
Old Feb 10, 2013 | 05:28 PM
cfdfireman1's Avatar
Perfect example of pads not bedded properly. http://www.stoptech.com/technical-su...nd-other-myths
Old Feb 10, 2013 | 05:53 PM
latreille's Avatar
I,ve changed tons on pads and rotors, this has never occurred. And I did bed them in properly. but thanks for the info.
Old Feb 11, 2013 | 05:36 AM
TommiM's Avatar
interesting.. So you are certain that your bushings are in good shape? Basic things like checking that out and making sure your front end suspension and steering is properly torqued down, and no excessive free play on things, are good first steps.
Old Feb 11, 2013 | 10:45 AM
Make up your mind
Evo brakes are not the same as those on your average grocery getter.
Old Feb 11, 2013 | 05:59 PM
drive955i's Avatar
You stated that you've changed pads/ rotors before, but just make sure your hub is clean of rust and debris. If not, the deposits will upset the straight running of the rotor in relation to the hub, and will cause vibration under braking.
Old Feb 13, 2013 | 06:22 PM
latreille's Avatar
was bad rotors again, came out of the box warped. Had the new was turned and problem solved. Thanks for all input guy's.
Old Feb 13, 2013 | 11:04 PM
Grimgrak's Avatar
I machined rotors and tried 3 sets of pads quietest being the stoptech streets. However when I go to a place that blows snow and water/snow gets into the wheel.... as soon as I touch the brakes backing out it squeals SUPER loud. Only way to get rid of it is to heat the brakes up.... impossible to do leaving a packed resort.
Old Feb 14, 2013 | 02:33 PM
myth
ProfessorX
Sep 5, 2011 06:17 PM
jameswwt
17
Jun 2, 2011 02:30 AM
lancerhero
Jan 12, 2008 04:21 PM
chet
16
Oct 16, 2007 02:28 PM
CAD EVO
Sep 9, 2005 03:56 AM
