License Plate Blocking Brake Cooling
Hey guys,
I just purchased my 2005 tarmac black evo and got 0% financing. I love the car and it handles remarkably. My one question is: My front license plate holder seems to block the left sides cooling inlet. It seems to cover the two largest holes behind it. I was wondering if this could effect my brake cooling and engine cooling significantly, and if so is there another area to place my plate legally. I live in NJ so the front plate is a must. All help and info is greatly appreciated
thank you
thank you
Don't worry about it.......unlike the right side it has cooling inlet for the oil cooler, there's no inlet on the left side opening. For brake cooling duct....you need to buy an addition parts from the factory and do a mod on your front under tray.
http://www.mitsubishipartsstore.com/...56c0372063630c
your brake cooling ducts are more directed by your undertray...stick your head under and look, you'll see 2 channels directed at the back-side of the brakes...and like what was said, you can buy special brake cooling guides from Mitsubishi for added cooling effects.
your left duct also has very little effects on engine compartment cooling. The majority of that function is for the middle part of the front grill which, while moving, will force the warm compartment air out of your hood vent. Engine and radiator cooling-wise, the car is very well designed.
cool_as_crap
Jan 11, 2016 10:59 AM
