bouncy
Old Mar 7, 2013 | 08:50 AM
DYTNEvo's Avatar
bouncy
Hey guys just wondering if any one knew why my car is SO bouncy! It handles amazing in autocrossand around tturns etc... but its like its not even a daily driver... I have a ralliart coilover set up I believe stock everything else
Old Mar 7, 2013 | 09:28 AM
heel2toe's Avatar
Can you provide some additional information on your suspension setup? I am not familiar with the ralliart coilovers. Are they adjustable? Your struts might also be blown. Do you see any leaking fluid on the bodies of the shocks?
Old Mar 7, 2013 | 03:26 PM
analogEvo's Avatar
Adjustable coils? Maybe your preload on the springs is off
Old Mar 8, 2013 | 03:25 AM
DYTNEvo's Avatar
Yes they are adjustable. And I haven't seen any fluid anywhere on or around the coil itself. Im not looking to replace them because I do love the way they handle, just looking to fix the ride quality! Lol
Old Mar 8, 2013 | 08:42 AM
heel2toe's Avatar
Since your coilovers are adjustable and they dont appear to be blown, it sounds like they simply need to be adjusted. With coilovers you have adjustability at your fingertips with things such as ride height as well as dampening. Some will even let you adjust both bump and rebound.
While this is cool, is they arent set up properly then your car is going to ride like crap. If I were you I would have your car optimized by someone who knows what they are doing. This includes setting up ride height, alignment etc.
Old Mar 9, 2013 | 06:07 PM
analogEvo's Avatar
Again... Spring preload being wrong will make your car bouncy. Check the preload and what it should be set at .
Nyaim
20
Nov 9, 2014 05:04 PM
Axle211
Apr 26, 2011 07:27 PM
Dwalk08
Sep 3, 2010 10:55 PM
englandsemo
Lancer Tranny/Drivetrain Tech
17
Jul 5, 2009 11:27 AM
evo_skillz
Dec 30, 2006 06:09 AM
