Front Noise Suspension
Hey guys anyone else and their evo's have a small clickity click noise when turning and slowing down when going into park ways etc..? Thought it was my old stock suspension only.. the noise went away after installing coilovers but the noise came back. sounds like its coming from the front right coilover.
Oh and any reccomendations on some good long lasting pressure break pads that dont get so dirty and squeak the rotors so easy? thanks.
Hey guys did some reasearch people say it could be the outter cv joint... Clinking only low speeds and turning.. Inner is if it's clicking at acceleration.... I'm gonna check my boots soon and let you guys know!!
Shot in the dark, here, but have someone else turn the steering wheel while you hold the tie rod. Have them rock the wheel back and forth while you hold the rod. If you feel the rod moving before the wheel does, you may have an outer tie rod/inner tie rod loose. This type of problem becomes more noticeable as speed decreases due to higher loads on the tire. Noises from tie rods can happen over bumps, too.
pnoy_RA06
Jul 22, 2013 09:42 PM
xsvboost
Nov 13, 2012 02:33 PM
CantStopSpinin
10
Apr 10, 2011 09:37 AM
