Brembo Bleeder Screws.... HELP!
Old May 15, 2013 | 06:41 PM
jay777's Avatar
Hey guys, I've been searching far and wide for bleeder screws for my EVO 8.
I called the Mitsubishi dealership and they want $18 a piece for them and they said it's 3 weeks to get them in because they are "special order".
I don't want to go with speed bleeders, I want to stick with OEM if I can.
Does anyone know where I can find some?
I searched on lancershop.com and they list two different ones; a front set and a rear set. I don't know which ones I need because all my bleeders are the same???
I also came across this website:
http://www.yoyodyneti.com/Category.aspx?CategoryID=3014
Does anyone know if either of the two M10X1.0 will work??
Any help will be greatly appreciated!
Old May 15, 2013 | 08:05 PM
matrho2792's Avatar
http://www.streettunedmotorsports.co...7_mr407368.htm
They are all the same size. Hope this helps.
Old May 15, 2013 | 08:07 PM
jay777's Avatar
I'm ashamed to say I never even thought about STM
Thanks a lot!
Old May 16, 2013 | 01:07 PM
matrho2792's Avatar
Not a problem, glad I could help. I've used them for a lot of OEM parts and they are great to deal with. If you have any questions just give Jeremy or Brian a call and they will get you set up.
Old May 16, 2013 | 08:09 PM
jay777's Avatar
I called them today and dealt with Brian. He didn't have enough in stock but has put an order in for me. I also ordered the STM full SS clutch line after lurking their site.
Brian was great! The shop is only an hour away from me as well. Bonus!
Thanks again
Old May 22, 2013 | 02:05 PM
WI-EVOS's Avatar
Glad u found some!
Old May 27, 2013 | 01:21 AM
MRaculous's Avatar
Maybe you can call Race Technologies and ask them for Brembo's part number and get it through a Bremo dealer. They are the US Brembo distributor. Just an idea, hope that helps.
EDIT: I see problem solved after reading further down. Will leave the comment for future readers...
Old May 30, 2013 | 12:49 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
For posterity's sake:
https://www.pegasusautoracing.com/pr...1-2&RecID=5040 - oem cap $2/ea
Brembo rubber caps: MR407368 - $2.56
Brembo bleeder valve: MR407367 - $6
Replacement front pin: MR475933 - $8.13
Replacement rear pin: MR475934 - $3.04
Brembo seal kit: MR407375 - $114
http://www.zeckhausen.com/Brembo/Con...es.htm#Rebuild
http://www.shop.motorsportsperforman...rs-BM-41BS.htm
4 Oil Seal (2x46mm, 2x40mm)
4 Dust Boot (2x46mm, 2x40mm)
$72.00
jimbo74
13
Aug 29, 2016 09:25 AM
rob_d
27
May 2, 2016 09:23 PM
ehnde
Jul 13, 2010 01:01 PM
MICLOIV
May 27, 2010 01:32 PM
jcnel_evo8
May 2, 2004 08:18 AM
