suspension adjustment
Sup guys, bought a 06 IX about a month ago and I've been going thru the while car fixing issues and came across a problem.
Installed are fortune 500 coils with xd9 18x10 wheels and everything was way oit of adjustment. So I took everything off and reinstalled and made both dr and ps side even but No matter What I do Dr side is about 1/2 inch lower, threads are even bothsides and camber bolts and eveeverything. Any ideas?
Could be a blown strut or weak gas charge in one.
Have you checked all the eccentrics on the rear and made sure they are properly installed? No worn bushings or bad ball joints ? all the strut bolts are OEM up front and camber ones both pointing in or out ?
Did you measure your coilovers at the shock body? Are you completely sure that they are at the same height? Did you change the height? Camber bolts do not change the height of the vehicle but the camber will be off if they are in different positions. They way you have described means that your camber is set to -2 degrees in the front.
Dr.G
Feb 27, 2015 09:50 PM
Migsubishi
Nov 2, 2012 06:18 PM
Migsubishi
Oct 11, 2012 08:40 AM
