Evo 8 wheel choice ?
Old Jun 22, 2013 | 07:18 PM
03Evoftw's Avatar
17x8.5 Enkei RPF1 Rim 5x114.3 +30mm Offset 73mm Hub Bore
235-45-17 tires
With this set up work with an evo 8 that is on lowering springs not slammed. With out wheel spacers!
Old Jun 24, 2013 | 09:32 AM
03Evoftw's Avatar
Bump
Old Jun 24, 2013 | 09:40 AM
vortico's Avatar
The offset sounds a bit close for comfort, you will probably need spacers to clear the brakes in the front. Stock wheels are 8 inch +38 offset. My setup has RPF-1's in 9.5" with a +18 offset and I needed to bring that back to basically +38 with a 20mm spacer to clear the brakes.
Old Jun 24, 2013 | 10:44 AM
heel2toe's Avatar
That size fits fine and clears the calipers without the need of a spacer. For the RPF-1's the 17x8 +35 and the 17x8.5 +30 will clear the brakes however the next size up 17x9, I forget the available offsets off the top of my head, will not fit without a spacer.
Old Jun 24, 2013 | 11:33 AM
sujinX's Avatar
^^ +22
Old Jun 25, 2013 | 10:01 AM
03Evoftw's Avatar
So what is the best size to go with to clear the brakes and if possible no spacers im not sure what was ment with the last 2 posts. So is the 17x8 with +35 offset the best and works without spacers?
Old Jun 25, 2013 | 10:33 AM
03Evoftw's Avatar
Is there an rpf1 17inch that will fit without any spacers and 235-45 on it. I can't find any verification of it and I'm worried about ordering them wrong
Old Jun 25, 2013 | 10:42 AM
heel2toe's Avatar
As I said in my post yesterday either a 17x8 +35 or a 17x8.5 +30 will be a good choice for you. The larger ones will be a little more aggressive in that they will stick out a little further and are .5" wider.
If I were choosing between those two I would go with the 17x8.5 but honestly if you are just dd the car and dont plan on running anything larger than a 235/45 then you will not notice a difference.
Old Jun 25, 2013 | 11:19 AM
03Evoftw's Avatar
Is there any advantage to running either the 8 or 8.5 wide with a + 40 offset
Old Jun 25, 2013 | 11:47 AM
heel2toe's Avatar
Not at all. The stock offset is +38 so I dont even know if those would fit.
Old Jun 26, 2013 | 06:20 AM
grillpt's Avatar
+40 won't fit.
If you are dead set on not using spacers use the 8.5" +30mm. Wider than oe and still not using a spacer.
Old Jun 26, 2013 | 11:35 AM
03Evoftw's Avatar
Would the 8.0 with +35 offset be the best then, cause I won't be going bigger than 235/45 for the tires
Old Jun 26, 2013 | 11:40 AM
03Evoftw's Avatar
Was looking to keep the weight to a minimum on them. Just worried about making the orde untill in sure what is best. Thanks for all the help
Old Jun 26, 2013 | 12:00 PM
heel2toe's Avatar
If you wont be going larger than a 235/45 and weight is of a concern to you then stick with the 17x8 +35. IIRC I think they are ~.5lbs less per corner than the 17x8.5 +30
Old Jun 27, 2013 | 08:11 AM
03Evoftw's Avatar
5.79 for back spacing is good for the 17x8 +35 also. That's what tire rack showed
