Brembo O- Ring size
Old Jul 19, 2013 | 10:26 AM
thedru13's Avatar
Brembo O- Ring size
Quick Question. Does anyone know the size of the o ring for the brembos when you take them apart? I have tried a 6mm ID x10mm OD x 2mm W. Seemed a bit small and a 7mm ID x 11mm OD x 2mm w and that seemed to fit ok.
Wanted to confirm before i put them all back together.
Old Jul 21, 2013 | 08:05 PM
Syringe's Avatar
I intend on getting my brake pads redone in the near future, I would also appreciate the answer to this if anyone knows.
Old Jul 21, 2013 | 08:36 PM
cfdfireman1's Avatar
it's all right here, don't stop after the first 10 results. learn how to fish, eat for a life time
https://www.google.com/search?as_q=b...pe=&as_rights=
Old Jul 22, 2013 | 10:44 AM
Raptord's Avatar
You don't take the calipers apart to change pads so this o-ring won't be a factor.
Old Jul 22, 2013 | 11:03 AM
rcheung's Avatar
You can also buy an inexpensive digital caliper(the ruler not the brakes) and measure the diameters yourself.
Old Jul 22, 2013 | 11:08 AM
thedru13's Avatar
I did google it and i can't find anywhere that actually gives the size of that little o ring I have pointed out. THe replacement kits don't sell them. I found one video that says its 6mm but its from the G35 forum. but the 6mm seems a bit smaller and the 7mm fits better. So I am still unclear on the actual size of this oring.
Old Jul 22, 2013 | 04:59 PM
rcheung's Avatar
After a quick 5 minute search it looks like the o ring will be impossible to get. Its a round gasket with a sleeve.
http://www.6thgenaccord.com/forums/s...ad.php?t=33097
Also even brembo themselves wont sell them because they are apparently never suppose to be taken apart.
http://my350z.com/forum/brakes-and-s...eally-wtf.html
Old Jul 23, 2013 | 07:05 AM
Syringe's Avatar
Yeah.. I mean't calipers, sorry.
Old Jul 23, 2013 | 08:07 AM
thedru13's Avatar
Not being Lazy I have done a bunch of searching. but pretty much came to the same end result. Not a good thing to take them apart. My PC asked me to do so. In any case I am going to try and put them back together. After reviewing the links that you sent here is a suggestion on the part that could be used as a replacment but no one has commented whether its a good replacment or not.
That is what you need, order from http://www.mcmaster.com, item number 9464K113
Type - O-Ring
O-Ring Type - Standard
Cross Section Shape - Round
Width
3/32"
Actual Width
.103"
Inside Diameter
1/4"
Actual Inside Diameter
.237"
Outside Diameter
7/16"
Actual Outside Diameter
.443"
Material
Viton® Fluoroelastomer
Viton® Fluoroelastomer Type - Standard
Durometer - Hard
Durometer Shore
Shore A: 75
Temperature Range
-15° to +400°F
Old Jul 25, 2013 | 09:50 AM
thedru13's Avatar
I was also able to find this....
http://www.knsbrakes.com/c/car-item/...ss+Over+O-Ring
Old Oct 17, 2017 | 10:02 PM
WRX-17's Avatar
Even though this is an old thread I wanted to add some info about the Brembo cross-over o-ring size since it was difficult for me to find myself. I hope this helps someone in the future.
The o-ring needed for the cross-over between the 2 halves (if split apart for powder coating) is not readily available since Brembo does not advise doing so. After purchasing some from McMaster.com as suggested by another thread, I found out that they were far from being the correct size. These are the ones that were suggested, but DO NOT buy them as they are too big:
Chemical-Resistant Viton® Fluoroelastomer O-Ring
3/32 Fractional Width, Dash Number 108 P/N: 9464K113
https://www.mcmaster.com/#9464k113/=19hmijh
The ones that KNSbrakes.com sells are correct. Since they don't give any info on them I have to assume that they are Viton material.
I purchased these after the wrong mcmaster ones and measured them to find out what they are and to share the info. I measured the ID with a pin gage and the OD with calipers while on the pin gage to resist deflection. I have added the photos below to show the correct measurements.
The Brembo cross-over o-ring is M1.78x6.75
Cross section/Thickness: 1.78mm [.070in]
OD: 10.31mm [.406]
Here is where you can buy them in the correct material and size:
Viton®/FKM O-ring 6.75 x 1.78mm Price for 25 pcs
Price: $5.70
SKU: 675178MMV
http://www.oringsandmore.com/viton-f...ce-for-25-pcs/
Or they have an ebay store as well.
I sure hope this helps at least one person out there!
http://i11.photobucket.com/albums/a1...017_204925.jpg
http://i11.photobucket.com/albums/a1...017_204807.jpg
http://i11.photobucket.com/albums/a1...017_204701.jpg
Old Oct 19, 2017 | 03:26 PM
Raptord's Avatar
Use Imgur or something else for your pictures please, your photobucket-hosted ones aren't showing.
JKL_AP1
Mar 13, 2018 10:17 PM
SaltySilver
Jan 8, 2018 05:32 AM
DagYo369
For Sale - Cars For Sale
39
Sep 13, 2017 05:49 PM
boczo777
Aug 10, 2017 10:08 AM
evotuner04
For Sale - Part Outs
13
Dec 2, 2016 10:09 AM
