RPF1 powder coating info needed
Old Feb 16, 2014 | 07:01 PM
Czarcasm's Avatar
Anyone got their wheels done and had balancing issues? I know that the coating process is basicly bacing the powder til it melts, will this affect the wheel strength/shape because theyre magnesium?
Old Feb 16, 2014 | 07:36 PM
SmurfZilla's Avatar
RPF1's are magnesium? I thought they were the regular aluminum/cast. The powdercoating proess should mess with the integrity of the wheel.
Old Feb 16, 2014 | 07:44 PM
xXANCHORMONXx's Avatar
They are cast aluminum
Old Feb 16, 2014 | 07:51 PM
gmac03's Avatar
I've never powder coated RPF1's but I have powder coated numerous wheels. Typically stock wheels because I like to change the look but keep the stock theme.
Personally I've never had an issue with wheel integrity after I've powder coated them, nor have I ever had a balancing issue.
I've read numerous threads in regards to powder coating weakening the metal structure, I just don't be believe that's the case with the cooking process (it's not that hot). Ultimately this is where the metallurgists chime in and tell me I'm wrong..whatever.
Find a reputable powder coater that has worked with wheels before, then post up the pics.
Good luck.
Old Feb 17, 2014 | 11:43 AM
Neal@tirerack's Avatar
Power coating require a bit of heat for things to stick. Make sure the wheel does not get too hot or you may have issues with it. Find someone that knows what they are doing and not a "professional" with a craigslist oven in his garage.
Old Feb 17, 2014 | 09:15 PM
codgi's Avatar
This. A company this is accustomed to powder-coating wheels won't heat them to the point that they do damage them.
Old Feb 20, 2014 | 07:56 AM
SmurfZilla's Avatar
Detective Coatings comes to mind.
Old Feb 20, 2014 | 09:46 AM
projektevo9's Avatar
+1 This is where I go for all my coating.
Old Feb 20, 2014 | 09:54 AM
meckert's Avatar
Powder coating heats to approx 400f--no need for more and shouldn't vary by much from shop to shop.
Old Feb 25, 2014 | 03:34 PM
tommyf's Avatar
Intrack tires in Queens NY does great work highly recommended! Powder Coat any wheel
e\/olution
Northeast Region
Oct 27, 2011 06:18 PM
stealthyevoviii
Mid-Atlantic Region
24
Aug 20, 2009 06:29 PM
WEVO
Midwest Region
Mar 23, 2007 08:58 AM
XK120
Northeast Region
Jul 4, 2006 05:00 PM
