SuperPro TRC0001
Old Mar 10, 2014 | 06:44 PM
aggieEVO's Avatar
SuperPro TRC0001
Has anyone used this? I can't find any reviews on the forum. It's SuperPro's version of the Whiteline RCK.
Curious as to the quality.
Old Mar 11, 2014 | 04:57 PM
WRC-LVR's Avatar
im using Superpro in the rear. work very well.
Here is the entire listing of SuperPro for the EVO 8-9 for those who wish to inquire etc. They do have USA distributors, check their website.
Control Arm Lower-Inner Front Kit
Front SPF2418K 1 Inner Tubes, Bushings
Control Arm Lower-Inner Rear Eccentric
Offset bush to increase caster Front DURO3741K 1 Bushings
Control Arm Lower-Inner Rear Kit
Upgraded stiffness in bushing but with no compromise in articulation. Front DURO3739K 1 Bushings
Control Arm Lower-Shock Mount Kit
Rear SPF2072K 1 Inner Tubes, Bushings
Control Arm Upper-Inner Front Bushing
Rear SPF2062K 1 Inner Tubes, Bushings
Control Arm Upper-Inner Rear Kit
Rear SPF1974K 1 Inner Tubes, Bushings
Differential Pinion, Bracket Mount Kit
45mm outside diameter bushing Rear SPF1975K 1 Inner Tubes, Bushings
54mm outside diameter bushing. Rear SPF2543K 1 Washers, Inner Tubes, Bushings
Differential Support Bracket Mount Kit
Rear SPF2544K 1 Outer Shells, Inner Tubes, Bushings
Roll Centre Adjusting Ball Joint
2 x Ball Joint & 2 x Tie Rod End; Ball pin thread 10mm. Front TRC0001 1 Ball Joints, Rods
Steering Rack & Pinion Mount Bush.....Power Steering
EVO 8 only "Not USA Spec Vehicle" Front SPF2489K 1 Inner Tubes, Bushings
SuperPro Alignment Kit
SPF2418Kx1,SPF2489Kx1,SPF2072Kx1,SPF2062Kx1, SPF1974Kx1,SPF1975Kx1,SPF2544Kx1,SPF2601Kx1,SPF197 3Kx1 See notes against part# F & R KIT142K 1 Outer Shells, Inner Tubes, Bushings
Sway Bar Mount To Chassis Bushing
Measure bar diameter, 24,25,26,27,28,29,30mm available Front SPF1451-_ _K 1 Bushings
Measure bar diameter 21, 22, 23.8, 24.5mm available Rear SPF2073-_ _K 1 Bushings
Toe Control Arm - Inner Bushing
Rear SPF2063K 1 Inner Tubes, Bushings
Adjustable, Offset tubes in kit Rear SPF2601K 1 Inner Tubes, Bushings
Trailing Arm Lower Front Bushing
Rear SPF1973K 1 Inner Tubes, Bushings
Thrilla
Jun 24, 2017 03:14 PM
flawlessninja
Mar 31, 2017 04:26 PM
killerpenguin21
Sep 11, 2016 06:09 PM
AndyCT9W
Aug 19, 2016 01:58 AM
dsmdion
Oct 28, 2015 06:41 PM
