Fitment question!!
Fitment question!!
ok si i was test fitting some 17x9 +45 rpf1s, and the rear fit fine with a 10mm spacer. But in the front i put a 10mm spacer and spoke hit caliper. i put another 10mm spacer on and spoke STILL hit the caliper. So with basically a 20mm spacer it didnt work.
my question is, would a set of EXT studs make a difference in the spoke not hitting the caliper with a 10mm spacer on?
studs don't change anything in regards to spacing.
You should be looking at 17x9 +20 or +30 (if they are available in those offsets). the spoke design of +45 is TERRIBLE for evos
CodyJamesBitxh
Mar 8, 2016 06:02 PM
supaduckie8113
Jan 30, 2015 10:04 AM
ksevo8
15
Jan 27, 2012 06:24 PM
617G
Aug 19, 2009 10:20 AM
