Need Alignment Specs for 255/35/18
Old May 29, 2014 | 07:19 AM
romogst's Avatar
My current wheel/tire setup on my Evo 9 is 255/35/18.
I am going to take my car to get the alignment done and would like some recommendations on the alignment specifications for my setup. Car is mostly used on the streets with the occasional drag/road course events once in a while.
Old May 29, 2014 | 10:00 AM
MechTech's Avatar
If you are on stock suspension use stock specs. If not search around the forum. Common alignment is around -2 front camber -1.25 rear and 0 toe all around.
Old May 29, 2014 | 10:44 AM
romogst's Avatar
I'm not on stock suspension, I have coilovers.
Old May 29, 2014 | 12:40 PM
ReidFletcher's Avatar
Tire size is irrelevant to alignment in most cases; unless the car is stancenation and you need obscene amounts of camber to clear fenders, or the car is raced heavily and every bit of traction counts. Alignment really depends on driving style and vehicle use. If your rarely going to track it then I'd keep the camber around 1' (1.5'max). 0 toe in the front and a touch(1/32") of toe in for the rears to encourage the car to track straight.
nor11384
May 19, 2016 05:43 PM
evol ways
15
Nov 1, 2009 01:05 AM
acidandroid
For Sale - Wheels / Tires
10
Mar 10, 2007 01:58 PM
beast464
Dec 22, 2004 03:31 PM
