Free caster mod
Old Oct 24, 2014 | 09:54 PM
domyz's Avatar
Originally Posted by jdmdc2r01
I didnt notice a difference at all for some reason. I did it same time with the Roll center kit. <br />
All that work for nothing...besides having more caster and having to remove my fenderliners.
<br />
<br />
So you have to run without liners? <br />
First time I heard of that
Old Oct 26, 2014 | 11:57 AM
osetsky's Avatar
I think we would all like to know more about your fender liner issues.
Old Nov 6, 2014 | 09:34 PM
mrfred's Avatar
Originally Posted by Ang Wen Yan
Yes,Perrin discontinue all EVO parts
Alternative is Whiteline KCA400M
has anyone tried the KCA400M? it looks like it is a sealed unit.
Old Nov 11, 2014 | 02:14 PM
cerevo's Avatar
I just installed the Perrin bushings PSRS's and so far I like them. There is a little bit more noise but I wouldn't say its not daily driver worthy at all. The only time I notice it is over repetitive bumps that are constantly pushing the wheel upward/downward and even then its not that bad.
If youre car is totally stock you'll notice it more probably than if you have other mods that already add NVH
Old Nov 12, 2014 | 02:24 PM
intj123's Avatar
I just installed the perrin psrs too. And I think they are perfectly fine for DD so far.
When they are brand new they clicked a little but I think they just had to be broken in for 1 day, today it felt very smooth, yet stiff and stable, I have bilstein struts so it's on the soft side already and I didn't mind adding more stiffness.
I also changed the front swaybar bushings to energy suspension while I was there. Front end is super stable now, steering wheel is stable and doesn't wander and jiggle over bumps and during braking.
Old Oct 23, 2016 | 10:04 PM
pawpaw's Avatar
Hey guys I noticed the top rubber mount of my car is showing signs of wear, and the suspension is making some clunks when going slow over bumps. From the photo, is it very serious? Can I delay by 2 mths before replacing the mounts during my routine maintenance?
%5BURL=http://s917.photobucket.com/user/philipho827/media/Mobile%20Uploads/IMAG0202_zpstpvsye48.jpg.html%5D%5BIMG%5Dhttp://i917.photobucket.com/albums/ad19/philipho827/Mobile%20Uploads/IMAG0202_zpstpvsye48.jpg%5B/IMG%5D%5B/URL%5D
Old Oct 23, 2016 | 10:31 PM
domyz's Avatar
I think I gave this trick somewhere on evolutionm but here is it:
Most of the time, the issue with a loose strut mount is that the bearing inners become loose in their housing. The trick is to remove the mount, tap on the bearing cage lip, all around to bend it downwards, tightening the bearing. This will fix it for a very long time.
ILoveAWD
Pacific Northwest
Jun 16, 2012 10:01 AM
OakosAutomotive
EvoX 'For Sale' Wheels / Tires
122
Jul 9, 2009 12:33 PM
Darius@AMS
Automotosports - Illinois
Apr 4, 2008 03:08 PM
Darius@AMS
10
Nov 18, 2007 03:45 AM
Darius@AMS
Midwest Region
Nov 14, 2007 04:30 PM
