drive shaft problem
Old May 22, 2015 | 06:21 PM
yeayeaatou's Avatar
drive shaft problem
The first 2 shafts are fine, the 3rd shaft has the big bushing in it and its blown out.
I have some play in the shaft any ideas?
Old Jun 2, 2015 | 08:42 PM
barneyb's Avatar
I'd suggest searching for a used one. Mitsubishi offers only entire driveshafts - expensive. If memory serves, you could get parts for that joint for a DSM. That was a long time ago but maybe worth checking into. I couldn't tell you if they are even the same. They look the same.
Old Jun 4, 2015 | 06:15 PM
blockade35's Avatar
$150 on ebay for the whole used OEM assembly shipped.
Old Jun 5, 2015 | 03:05 AM
yeayeaatou's Avatar
I saw them on ebay. But it looks like the rubber is blown out on the 3rd joint on every driveshaft. So i guess my question is that a normal problem? If it is how can I know if that shaft has play? Mine does have play between the 2nd shaft and the 3rd. I think it causes a clunk while shifting
Old Jun 5, 2015 | 12:06 PM
barneyb's Avatar
The FSM states, "Be careful not to bend the joint portion when removing the propeller shaft because this will damage to (sic) the joint boot. Insert a rag so as to avoid boot damage, and remove the propeller shaft assembly in a straight and level manner."
Well, I think nobody knows this. Bend the drive shaft too far at the joint and you have a cut boot. I have a jig I use which clamps onto the drive shaft and holds it straight for removal.
Anarchy99
11
Mar 7, 2012 12:17 PM
BlackonBlack2
Feb 26, 2012 05:58 PM
okevolutionVIII
33
Oct 30, 2011 08:05 PM
sterdyevo
12
Dec 8, 2007 12:08 PM
mrblob20
Dec 26, 2006 07:47 PM
